Dum-Dum Yup, that's what it was called back in the day. It was used by a lot of body shops as a fit-all seam sealer and anti squeak between 2 metal panels. I still find it today. I use it when I mount SS to side body panels to keep water from getting in through the mounting bolts/clips. One version is the white "flexible gasket ribbon" sold at all RV stores in 1" 1.5" and 2" wide (with a paper liner )to seal the doors and vents. It stays soft. The other is a black butyl seam sealer in a rope on a paper liner sold at all body shop/paint suppliers. This is a good product to use for wind gasket leaks after repairs. It is 3M or Tremco brand in 1/4", 3/8", and 1/2" It sticks like grim death and stays flexible. I stock all 6 in my shop and use at all seams and joints. The Dum-Dum is used to hold shims,washers,panels,and nuts in place if working alone or for temp mounts to test fit. It will squeeze out as you tighten. Handy man's best friend like duct tape IMO. :-blah
