Ford Truck Enthusiasts Forums
-   Aftermarket Products (https://www.ford-trucks.com/forums/forum66/)
-   -   After market cruise control... (https://www.ford-trucks.com/forums/271126-after-market-cruise-control.html)
mikefox670 08-13-2004 07:23 AM
Where can one buy an after market cruise control for a 1998 F150 4.6L?
mikefox670 08-14-2004 05:31 AM
Found a great cruise control at
http://www.halsautocare.com
Check out the manufacture’s (SCS) site for the Micro Processor Power Cruise Control.
http://www.scsfrigette.com/html/products/cruise.htm
ClydeSDale 08-16-2004 12:43 PM
I had three different aftermarkets in a '76 E150 window van that we had for 14 years. They work for a while and then they die. Very discouraging x(
When I got Clyde back in '96 it didn't have cruise and that's something I don't like to live without. From past experience I decided I wasn't going to dink around with add-ons. I pulled a complete system out of a "donor" '82 and haven't had any problems since installation.
IMO it's hard to beat a Ford factory system. I checked with out parts people (I work at a dealership) and depending on labor rates should be able to get one installed at a dealership for $6-700. Higher labor rates will add to that number.
Good luck with it...
hhott71 08-24-2004 11:27 AM
www.bought4less.com
sells the SCS/Frigette cruise at the best price.
98 f-150's are an easy install
yota 08-30-2004 02:36 PM
[QUOTE=ClydeSDale]I had three different aftermarkets in a '76 E150 window van that we had for 14 years. They work for a while and then they die. Very discouraging x(
what parts do you have to remove from the doner i have access to a junk yard full of them butt most are in computer controllerd cars. i wonder if the computer is needed?
ClydeSDale 08-30-2004 04:00 PM
Gotta think a little .... and I may be forgetting something ...
Steering column complete, control box under dash, modulator with cable to carb, two-piece speedometer cable with sender unit, all related brackets and wiring harnesses. It's mostly a matter of following "the flow" of the cruise control system.
I realize this may sound a little vague. I spent a fair amount of time studying service manuals and maintenance guides ( Chilton, Haynes, etc.) plus having a friend or two at a Ford dealership ... and as a further excuse it was a few years ago :rolleyes:
ClydeSDale 08-30-2004 05:34 PM
I should also have added :-X17 that the donor vehicle should be as similar as possible to the recipient. Parts for my '85 F250 cruise control transplant came froml an '82 F250.
Roger
64,500 original miles (and counting)
bavaria72 09-28-2004 03:33 PM
I have a 2004 Sport Trac and I would like to put cruise on it. The knockouts for the steering wheel cruise control paddles are very easy to get to. Does someone make an aftermarket kit that has these paddles (or similar) and rest of the required pieces in a single kit? I have put cruise on several other different vehicles (VWs, T-1000, and CJ-7) so I'm not too worried about the difficulty but I sure would like to be able to put something on that looks half way original instead of the typical J.C Whitney 2" by 1" control box. Thanks
hhott71 10-04-2004 09:58 AM
check out www.bought4less.com
they have wheel switches, add on column switches and last resort dash switches.
bavaria72 10-04-2004 02:55 PM
Thanks for the site. I had looked at them eariler. Looks like they are about the only game in town that has wheels switches. Thanks again.
jmurphy_5 10-15-2004 07:19 PM
anybody know how hard it would be to pull all the parts of truck at junk yard and reinstall them
bavaria72 10-16-2004 11:41 AM
I would doubt the junkyard would let you pull just the switches off unless the airbag was deployed and the wheel was broken. If you could find one in that condition, it looks like a fairly simple operations. Heck if you can find one like that (and the switches not broken) have them pull the entire steering wheel and then it would be very easy to remove them at home.
