What years interchange?????
I recently bought a 89 F 150 2WD off a guy who had apparently ticked off the wrong people. The windshield, side glass, rear glass, taillights and headlights are all broken. What year/models will interchange with mine?? I have an old (probebly early 80s) Ford van sitting out back, will the windshield and side glass interchange?? Thanks for any help.
80-96 F series glass should fit and 88-91 lights. I doubt if you can use anything off an E series.
Jim |
I once asked the same ? think i was told 87 too 95 where some what inter changeable in most parts.. :-X01 :-X01 :-X01 :-X01
Thanks for the replys. I did some measureing and the vans glass is much taller then the trucks. I guess I will have to start searching the junkyards.
<!nate o23--I have the door glass and aillights real cheap. I am in NW IndianaE-mail me off forum if you are interested.>
Please do not try to sell parts on our boards, it is against our guidelines. You may use the classfieds section we provide :) |
Be careful on the door glass. You have to use 87-96 or the window will not roll up and down. I found out the hard way that the 80-86 glass is about a 1/4" wider than the 87-96.
James |
Although alot of other body style years will fit your best bet will be used parts from the same body style. 87-91 F-series trucks will work perfectly.
You can also search salvage yards at www.car-parts.com |
jamesgs47 I would agree on the window size but if you use the older wing window and track the 80-86 work fine.
<!I just took a 89 off the road and plan on parting it out,from Lake George in up state New York, Hugh>
Edited for same reason as above, FTE |
Is it a 4x4 or 2 wheel that u are parting out
Originally Posted by Hugh1217
(Post 1575819)
Edited for same reason as above, FTE https://cimg5.ibsrv.net/gimg/www.for...64d67da6a.jpeg |
Originally Posted by transman123
(Post 19393158)
if its a 4x4 how much would u want for this part of the steering if u have it please call or text me asap at 3605958114
