Question about Suspension Lift kits..
I have a 01 F250 Super Duty Diesel 4 x 4..........
I am located in Maryland...and supposedly the law regarding lifts is 28inches from bottom of bumper to the ground. I am considering doing a 6 inch Edge lift kit with 35s, 6s, or 7s but dont want to be so far over limit the second it goes on i get pulled over. ..So Anyone out there with the same or similar truck can give me honest true measuements on front and rear bumpers just so i know what i woudl be looking at and decide from there. Also those with 4 or 4.5 inch lifts with 35s same thing.... Thanks for all help. Tony |
Hey Silver. I have a 01 also an I put a 4" Superlift on mine. I have 35's on it to. I went an measured an on the front bumper, from the ground to bottom of bumper measuring right in front of license plate is 241/4" and in the rear is 251/2" from ground to bottom of rear bumper. Hope this helps. Good luck on your lift install.
I am running a 97' with the equivelant of a 4" lift and 35's, older body style but I measure 29 1/4 front and 28 3/4 rear. Goodluck
Thanks guys for the responses. I appreciate it . Any guys out there with a 6" and whatever tires help me out to compare???
Once again appreciate all the help. Just want to do it right the first time. |
OK, I have an 01 4x4 Diesel with a 6.5" Pro Comp and 35's. The height from the ground to the bottom of the plastic part of the bumper is 26". Hope this helps.
I'm in MD. I know a guy with a SD and an 8" lift with 38s, and my friend has a old style 250 with a 6" lift and 36s. Neither have had any problems. The cops around here (locally) don't care about lifted trucks. Just my $.02.
I have A 6" lift with 35" BFG.
Front from concrete to license plate is 25" Back from concrete to bottom of bumper is 26 3/4" Hope this helps. |
