f-700 with cummins
I went to the local diesal performance shop today and saw in the back a f-700. I never heard of one so I went and checked it out and what I saw was a 5.9 cummins motor in it. Why is this brand new f-700 powered by a cummins
The only engines available above the F550 are the Power Stroke, the 5.9 Cummins, and a Cat. Personally, I would take the Cat over the Cummins or Power Stroke.
Thanks I didnt know the cummins was put in fords
i didnt think the powerstroke was available above 550. Seems to me it would be unerpowered a bit. Guess its like putting a 5.4 in a 350 c/c dually.
The 444 is mild when put into the small Ford trucks. They turn the computer up when they put it into the 6-750. The only difference between the 4-550 and the 350 is the frame rails are straight and stronger and the GVRW is higher. The 6-750's are available with the 444, cummins, and the cat. The cat is the only engine that can come with the optional auto transmission (allison)
Originally posted by FarmerPhilCo The only difference between the 4-550 and the 350 is the frame rails are straight and stronger and the GVRW is higher. Both the GVWR and GCWR are MUCH higher on the 450/550 than on the 350. |
the gcwr on a 350 is 20,000# and on a well equiped 550 its 26,000#, not much higher, but yes higher.
So, do the 6/750's with powerstoke come with a "factory power tune"? If so, is it possiable for a 350 to use a 750 computer? |
it is the same computer, just configured differently.
you can tkae your truck to an international dealer and they can reconfigure your computer |
What is different with the 6/750 tunes? Would it be safe to have IH recon the computer without any goodies (i.e. gauges, exhaust, etc.)?
Mike |
you dont want to over do it. You can have them turn it up just a little but if you go any further you will want to beef up the drive train.
Originally posted by f350xlt460 the gcwr on a 350 is 20,000# and on a well equiped 550 its 26,000#, not much higher, but yes higher. |
you have to have a cdl to drive your 550?
odd |
in VA i think you need a CDL for anything over 26,000
Casey, ive heard of that 30,000# package, whats different then the 26,000#? |
Originally posted by f350xlt460 in VA i think you need a CDL for anything over 26,000 Casey, ive heard of that 30,000# package, whats different then the 26,000#? And yes, I have a CDL to drive the truck and trailer. |
oh, Im not doubting that you have your cdl and are capable of driving a rig, I just foud it odd that a truck that small could be set up over cdl thats all. It has to have springs and axles that are huge, my friend has a 550 roll-back and just about anything on the rear lift will make that squat.
and anything over 26,000 requires the driver to hold a cdl unless it is a registered farm use vehicle. |
