1997 F350 Steering Wheel Alignment
I've got a 1997 F350 Powerstroke 4 x 4 and the steering wheel sits a little crooked. Does anyone know if there is an adjustment I can make to correct the alignment of my steering wheel. The way it is now it makes it very hard to keep the turn signals on at the appropriate time.
Thanks 1997 F350 4 x 4 Powerstroke 1988 F250 4 x 4 5.0 EFI 1975 F250 460 Hot Rod |
The tierod that goes from the steering box to the passenger side has a threaded sleeve and 2 clamps on it, simply loosen the clamps and use a flat screwdriver in the slot on the sleeve to turn, make small adjustments until your steering wheel is straight.
