interior lights stay on
Hi, I just signed onto the forum today. I have a F 250 diesel. It is running ok, but the "door open" light stays on and the interior light also stays on. I had to take the bulb out to shut it off.
has anyone had this problem or an idea of what the problem could be. Thanks a bunch |
Spray some WD40 into the locking mechanism this should do the trick;) Do a search for more info on this topic.
Manny:-X01 |
Soak the door latch with WD-40, open and close the door a few times, and soak it again with WD-40. This should do the trick, it's a very common problem with Super Duties.
Doh, AutoBahn got to it first!
rangerbud,
Just in case you/we overlooked the obvious... Did you check the dimmer switch for the dash panel? If you roll it all the way up and it clicks into place, it'll turn on the interior light. I've been guilty of leaving it on from time to time! BTW, welcome to the forum :cool: |
Hey guys this is really good. I appreciate your help. I surely checked everything I could find of course. The door ajar light stays on all the time the key is in the ignition now. It was sporadic until the last couple of days. I had to pull the bulb out of the dome light and the alarm is always dinging when the key is in the ignition but not running.
When you say soak the "door Latch", what does that mean exactly? I mean do I just spray a lot of wd 40 into the handle opening somewhere? Thanks a lot! bud |
No, spray it into the latch itself, on the inside of the door. Did the trick for me too! :D
Re: interior lights stay on
Originally posted by rangerbud Hi, I just signed onto the forum today. I have a F 250 diesel. It is running ok, but the "door open" light stays on and the interior light also stays on. I had to take the bulb out to shut it off. has anyone had this problem or an idea of what the problem could be. Thanks a bunch Bert |
Also check for a bad groung on the door light switch. I have an Explorer that had the same problem. Sometimes cleaning the contacts on the switch will do it. I don't know how the F250's are but some switches in the door frame ground with the screw, nut or bolt that holds them in place. If the contact area to the truck body or the screw/bold gets corroded the circuit is interupted.
Or it can be a faulty door light switch. In the case of the Explorer I tested first and when that did not fix it I changed the switch and that did it. |
Thanks again.
I haven't had a chance to try the latest tip yet. But some have mentioned checking the switches for grounding etc. I guess I will have to take all the door panels off since the swithes must be in the door. The swithches on the F250 are actuated (as best as I can tell) by the slider arms that are attached to the body and go into the door when it is closed. When you say spray into the inside of the door do you mean the latch where you squeeze to open the door? By the way I have 78000 miles on the truck. I still have the original Firestone tires on it. I have never ever come close to getting even 50,000 miles on a set of tires even for my cars. I am hoping to get 100,000 miles out of these tires. |
Hey rshober
I wasn't in F'ville, but I was aroung Albemarle all day. Trying to buy a home somewhere in that area. I don't think I am slamming doors anymore - although I did for a few days when this first started. By the way what does LMAO mean? |
Originally posted by rangerbud When you say spray into the inside of the door do you mean the latch where you squeeze to open the door? Is your SD a Super or Crew or Single? Originally posted by rangerbud By the way I have 78000 miles on the truck. I still have the original Firestone tires on it. I have never ever come close to getting even 50,000 miles on a set of tires even for my cars. I am hoping to get 100,000 miles out of these tires. |
Originally posted by rangerbud Hey rshober By the way what does LMAO mean? Bert |
this did the trick for me!! I’m a *******
Originally Posted by DS02F250
(Post 1323352)
rangerbud,
