Ford Truck Enthusiasts Forums
-   Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) (https://www.ford-trucks.com/forums/forum53/)
-   -   Stator/Pickup Coil Replacement (https://www.ford-trucks.com/forums/199148-stator-pickup-coil-replacement.html)
dcdave 01-31-2004 11:55 AM
78/46/C6/460J
I need to replace the stator in my distributor. Looks fairly simple except for one part. How does the little crowned flywheel (arbor?) come off the shaft. I can pull the keeper clip inside from under the oil sponge but that doesn't seem to free it completely. I see a small drift pin on the outside of the shaft but don't see how that's holding the flywheel to the inner shaft.
I have a tendency to snap things in two so before I apply too much pull to the flywheel I thought it best to ask for a seasoned solution. I'm listening. :-)
greenhighboy 01-31-2004 01:54 PM
Use two screwdrivers or prybars,one opposite the other and pry it up and off. They usually come off easy. Don't loose the little roll pin, it is what keeps it from spinning on the shaft.
Dennis
1999 F-350 Powerstroke
1977 Highboy 429 4-speed 35"s
1972 Ranger F-250 4x4
Pulling Truck
