oil pressure sensor location?
i need some help finding the oil pressure sensor
can anyone help |
davidson07
Welcome to FTE May I ask On what eng? Again welcome to FTE!!!!!!! WE all would like to help ya! Rich Ford Trucks Built Tough! not with rocks Watch out "X" Mayor of Truckville |
I think it's on the engine...look somewhere around there...
Sorry man...:-X10 It's gettin' late. Welcome to FTE & yeah, what Rich said! (The other Rich, I see you're a "Rich" too!) What engine? |
> > This is the valuable info I come here for!!!!!!:-X22 :-X24 |
>> >> > >This is the valuable info I come here for!!!!!!:-X22 :-X24 Good Morning Mr Davidson07! Can we be of some help in finding that oil sender unit! (sounds kinda feminen) Hey Yeti! is that better ? (sits back waiting for reply) 'x(') No offense Davidson07 WELOME TO FTE! Rich Ford Trucks Built Tough! not with rocks Watch out "X" Mayor of Truckville |
I just liked Monsta's directions.
Like asking where is California, and getting the answer on the planet somewhere...:-X24 I got excited thinking I would find out info for the mech oil guage , I guess I could look myself but, I may have to get off my arse for that!!:-X17 |
I think you can tap into a plug where the oil filter screws onto. But since I am at work "working" I do not have access to my handy-dandy CD manual to verify. So you'll have to wait.
it would have helped if i told you it was a v 10
but i found it the hard way 8 bucks later i am on the road again did a pressure check also it was 90 psi cold all is good |
where can i get a handy dandy cd manual
ps dont buy the chilton book it is worthless |
Try e-bay. :-X22 I'm wondering what you meant by "found out the hard way"... |
unplug sensors untill i found the right one
feminin?
i hooked my test gauge in the hole for the oil pressure sensor
just to make sure i had good pressure. im going to tee off of that and keep both i think it will work. ill try it and let you know |
some are on the right side of the engine by the fuel pump on a aluminum extension and some are on the back behind the carberator by the trani housing
