no brakes on f350
have replaced vacuum booster and master cylinder and pedal still goes to the floor even after being bleed 3 times.What am I missing?
Do you gots a leaky weel cylinder? try bleading backwards, from wheel up i had to to that to my clutch in my old blazer once.
Hey Roadwolf,
Did you find the problem? I'm having the same problem on my '95 F350. I suspect it has something to do with the accumulator that is mounted on the frame a little more than halfway back. I'm not sure if it gets bled by normal bleeding methods. Please let me know if you got yours fixed. |
