72 F100 And No Time
I HAVE A NICE SHELL (STARTING TO GET RUST SPOTS). ALSO 3 C-6, 1 GOOD, 1 OLD BOLT ON YOKE, AND 1 ?. GOOD HD RIBBED 390 BLOCK,40 OVER /W PISTON,RING,RODS,AND GOOD (H) HEADS. I WILL NEVER FINISH IT! IF I CAN HELP ANY NC FOLKS? LILLINGTON,NC.
Andrew, I hope that you can help some of your neighbors.
Anyone wanting to help Andrew help his neighbors please email him privately. You are welcome to use the Classified section on the site. John :-X06 |
by shell.... do you mean a cab .... if so ....i could use it
thanks john
thanks for understanding and for the direction.
andrew |
responce to rw-5
the whole truck. less motor and xmission. the two rear flat tires come with it. (will hold air) thanks andrew
Hi andrewh
Itried to email you by going through the profile, but the site says that I havent been a member for thirty days yet... so if you could email me by looking at my profile we can talk about removing the truck for ya.... thanks |
rw-5
seems im a new guy too. cant e-mail you either. lillington is a (910) area code. been here since 8/93. neighboor has a63 he has been working on since 92. shame we cant contact each other.
well.. we will see what we can do ..I live in the triad and work for the rr in the .com area... he he he. I have a 72 that only has 65000 miles on it, but the man that owned it used it to deer hunt . he had the frame horns cut off the front and had extensions added and a winch was installed. it is a 1972 10,000 lb warn cable operated winch.
the body mounts are shot due to the fact that first owner took it through all kinds of mud and never washed underneath. is your cab pretty solid in the mount area . when finshed i will put rwhitaker5 in the in the basement so i can never forget my username. hehehe |
rw-5
you were telling me about that 4wd. it dawned on me that i didnt say my 72 is only 2wd. hope thats ok. just thought you would want to know.
Yeah.. 2wd is really what i want. the original owner of my truck couldnt get into a 4 wheel drive......does your truck have power steering or disk brakes. Is it an automatic truck or a 3 speed manual
rw-5
has power steering and brakes. set up for automatic with drums all the way around 2yr old brake booster and master cylinder. the drums and shoes are good too.
Thanks andrew..it sounds good...what color is it...is the cab corners good... what size engine was in it....mine has a 302 with a three speed on the column...no power on anything....oh....is yours a short bed....
rw-5
jet black and the corners are good. had 360/auto in it. and yes i have the title. its well worth the drive, bring the tow dolly! ill have the tires pumped up and remove the c-6 out of it. unless you need one. this xmission is a good one. wanted to keep for when and if i finish my 390. this way ill have a good drive train for my 86. but if you need one, we could work something out.
Guys, I asked you use the classifieds, or take it private. This has become a private conversation in public. K.Payne made the rules and ask me to help inforce them.
click John |
