Some problems...
hey has anyone of you guy's trucks had problems when you unistalled the little "plumbing" system (i dont no what its called) when u put on a chrome air breather instead of stock, it was somthing to prime the carb so it starts better, but now mine most days plane doesnt start
BTW got new pics of the little 390 in gallery |
the pcv valve is that what you are talking about. if so it plugs to a full vaccuum port. you must have a vaccuum leak or something
is the carb and edelbrock or stock. on an edelbrock there will be a big port in front of it. that has to be plugged to the pcv.that is where i have mine at
its a Carter afb, and should i reinstall it, becuase right now i just have a plug on it, i will take a picture and put in gallery
Are you talking about the metal assembly that mounts on the exhaust manifold and goes up to the breather snout?
Clint |
