2003 F350 CC FX4 Tires
I have a 2003 F350 Crew Cab w/FX4 package, with stock BF Goodrich tires, 265 75R 16. I was wondering if I could go up a size without clearance to fender issues? Any experience with this would be appreciated.
There's been a handful of threads on upsizing tires and fitment in the wheel wells. With the stock 16X7, it is my understanding through recent threads here on FTE that you can go to a 285/75X16 fairly comfortably. I intend to do so when my current rubber (235/85X16 Michelin's) wear down. I intend to replace them with Bridgestone Revo's (min. load range D, possibly E) but on Eagle series 143 wheels, size 16X8. I'm more comfortable with the wider tire on a bit wider wheel (16X8 vs. 16X7), but that's just me!
BTW, I also have noticed that my supervisor at work has a 2001 F350 4X4 SD CC PSD with stock rims and 305/75X16's. He does quite a bit of traveling (hunting in CO, AZ; fishing throughout CA mountain terrain; etc) and has had no problems with load, wear, or rubbing... and he loads that camper shell down with gear and his buddies. Hope this helps, Daryl |
Daryl
Does your Sup, have a completly stock truck, or didi he level the front. I would think that the 305's would really grind on a rough left hander ? |
Originally posted by Kevin24 Daryl Does your Sup, have a completly stock truck, or didi he level the front. I would think that the 305's would really grind on a rough left hander ? |
Thanks
Im looking to go with the BFG's 285's, and am worried I'd rub, my stock 265's hit something now on a hard left hander under load, not sure if it's my springs, or mud flap ?? |
Nitto 33s work fine. I think its a 295, but I dont remember right now.
This is the third time ive posted this in twenty minutes!:) |
