How do you remove the ignition key/tumbler ?
I am trying to remove the ignition key/tumbler from my 2002 E-150. Does the end twist off? Or is there some other trick?
I'm not familiar with the E, but for most you turn the key to "ON", and, using a small diameter rod or punch, push up in the hole under the column shroud.
