2001 F150 5.4L 4 x 4 No Reverse
Got in truck today, engaged 4 x 4 drove around a while.
Parked truck. Got back in truck, started up, put in reverse Very Loud Metallic Clunk No Reverse Put in 4 x 4 no reverse All Forward gears work fine, drove straight and around in circle to check operation and all was fine Still No reverse When I put it in reverse it sound like something engages but it goes no where So what is the most likely thing that broke Thanks |
That article does not address the Loud Clunk
No Lights No Codes and shifts into forward just fine |
To diagnose the problem, you'll need to do the diagnostic steps outlined in the article or take it to a shop for a diagnostic. Simply knowing there was a noise isn't a diagnostic that will tell you the underlying problem. It simply confirms something happened and there is now a problem.
replaced
I replaced the transmission, took the old one apart and found the reverse band where the servo pushs in busted off IE the loud clunk
