351W roller engine?
Can you guys tell me if the Lightning came with a 351W roller engine? If it did what years were they?
Thanks! |
Some late 93 and all 94,95 have roller ready block but are not roller. Check the casting code above the starter to be sure, it will start with F4 if roller ready.
THANKS!:)
Originally posted by ecarter50 Some late 93 and all 94,95 have roller ready block but are not roller. Check the casting code above the starter to be sure, it will start with F4 if roller ready. |
Roller ready blocks have the correct castings/bolt holes for the "spider" that holds the roller lifters in place.
DO THESE BLOCKS HAVE ROLLER BEARING CAMS?
