Is there a best brand of coil spring spacer?
Ive decided on 1” coil spacers. I want to reduce my rake but not lift it enough to have to do anything else to my front end geometry.
Is there a best or preferred brand of coil spring spacer? I’m looking at the ReadyLift 1” spacers. |
I put the Daystars on mine. Im happy with them. They look factory. I did do a PMF track bar as well. But that was mostly cause i feel like the track bar is the cause of a lot of the death wobble. Though my axle was a little off center so i went ahead and made it perfect
Originally Posted by jjmoberg
(Post 20027481)
Originally Posted by Rob89
(Post 20027485)
My axle is 1/4” to 3/8” offset to the passenger side. I’m thinking a 1” spacer may actually center it.
I think as you go up...the axle moves to to pax side |
(Post 20027458)
Is there a best or preferred brand of coil spring spacer? I’m looking at the ReadyLift 1” spacers. if you want to wait a couple of weeks I’ll sell you my HD front springs off of my 21 platinum 6.7. They’re 1 inch or so taller than the std springs. I just ordered my Carli level & am waiting on tires |
Originally Posted by AZC
(Post 20027543)
Originally Posted by speakerfritz
(Post 20027535)
(Post 20027569)
Are they the 6000 lb snow plow springs?
they are equally tall. It was itemized as HEavy service front suspension on my order. |
