Brake line source
Looking for source: 1977 F600 frame brake line (front to back); Ford Part Number 2269
That's just the "basic" number. Probably easier to make the line yourself, just double flare the ends. ( after making sure the fittings are on.) Or, buy pre-made lines available at parts stores. Line diameter might be 1/4"
Napa has everything you need. Use the Nickel/Copper lines.
Originally Posted by GLR
(Post 19489857)
Hello and welcome to FTE. Don't forget to join the Missouri chapter.On the left hand side of your UserCP, you will see GROUP MEMBERSHIPS. Click on this and then find the chapter you want to join.
https://www.ford-trucks.com/forums/p...editusergroups When you have clicked on the "Join Chapter" next to your state, scroll down the page to where there is a Join Chapter button to click. Your request will be completed once your chapter leader (Me) accepts your request. Here is the place we all hang out and check in here on each other. Sept thread link. https://www.ford-trucks.com/forums/1...t-send-it.html Rich aka 77&79F250 |
Deleted...
