Hello 88 302 won't run
Just bought an 88 F150 xlt 5.0 old owner never got it running.Its been siting for 2 years in a garage.First thing i did was put fresh gas in it because from the smell it was old.
He put new wire's cap/rotor new plugs fuel pump filter.Got it running but was missing and black smoke.Had to keep tapping the throttle very fast to keep it runing would not idel. Then I replaced the TPS. I Checked the firing order its was 13726548 I looked you tube and It said that was wrong that is for 95+ Changed it to 15426378 still not running popping sounds like out of time The fuel pressure is 40psi does drop down.I m guessing I need New injectors. Going to look at plugs next.Any idea's thanks |
Welcome to FTE
The site is broken in to various section, (forums), with each designed to facilitate everyone being on the same subject. For your issues, we have: Older, Classic and Antique Trucks forums and Performance, Engines and Troubleshooting. Post your issues in those sections and you should get more responses than you can handle. Don't forget to check out your state chapter too. |
