4 barrel carb for 292?
Just got a ecz-9425-b intake manifold for my 292. What 4 barrel carbs do you like to run?
The Summit branded carburetors are about the best value available.
Originally Posted by charliemccraney
(Post 19344672)
I think Holley actually makes them. It's based on a Holley 4010.
Are you replacing the stock 2 barrel? I was curious if we could throw a four barrel carb to increase fuel flow but wasn’t sure if it’s possible.
I’m brand new to this engine as well as Fords. Thanks in advance! |
Assuming that the engine and fuel delivery system is stock, you are not going to increase fuel flow with a 4 barrell and there is no reason that you need to.
What a properly tuned 4 barrell can do is increase economy while also allowing for a little more power potential because of the extra cfm and the secondary metering, allowing for a better calibration of the fuel curve. But the key is properly tuned. |
Excellent info, I’m still learning al of this. Sounds like I can now look for a good 4 barrel EFI system. Looking to build a healthy and reliable engine for daily driving. Much appreciated!
Originally Posted by Johnny Ryall
(Post 19361476)
(Post 19361476)
Originally Posted by Nichalicious
(Post 19361541)
Also, welcome to FTE. This place is a wealth of information.
I’ve always wanted to convert an old engine to EFI. Thanks again for your help! |
What is your 292 in or going in?
Originally Posted by okiewelder
(Post 19364775)
I'm about to put on the new manifold and decided to repaint the valley pan and valve covers as well as new gaskets. Any pointers? It's been a while sine I have done anything like this...
l always take a lot of pictures and go slow and make sure l seperate all the hardware so l know how to put it back together
Don't overtighten the bolts. The specification for the valve cover and valley pan bolts is something like 2 to 2.5 ft/lbs - check your manual, get one if you don't have one. Very easy for a ham-fisted mechanic to overdo since they are 5/16" hardware.
