93 5.8 Fuel Bubbling Out of Pressure Valve
I have a 1993 F250 with the 5.8. Just had both tanks cleaned and new fuel pumps put in due to previous owner letting it sit. There's been a strong smell of gas for a couple weeks, and when I investigated today, I found that there's fuel bubbling out of the pressure relief valve near the front of the fuel rail on the driver's side.
Does that indicate a deeper issue or can I just replace that little valve and be good? I've had to put a lot of money into this truck and don't want to go crazy replacing fuel rails if I don't have to. |
Sounds like the schrader valve is just bad. It could also be dirty. Use a little screwdriver or pick tool and blip it a few times while it is pressurized and see if it clears out.
Thanks! Got a part# for that valve? Still bubbling after clearing, and local parts places can't find it.
try giving it a little tightening. you can get a schraeder valve installation/removal tool at any bicycle or similar shop.
Any auto parts store should carry it. They call it a tire valve core or valve stem removal tool. I would pick up a new vale core/stem while there and just replace the old one. The top of the one shown is what you remove and replace the stem with. Sandy
https://cimg7.ibsrv.net/gimg/www.for...9ed35aa57f.jpg |
Originally Posted by joey2fords
(Post 19105604)
Cool - will a tire valve core work for this thing? Afraid the fuel might eat it.
Pressure Relief Valve, Ford Part EOAY-9H321-A, still available.
Plastic Cap For Valve, Ford Part EOVY-9H323-A, still available. |
Originally Posted by R&RFord
(Post 19109162)
I put fuel pressure gauge on mine, when it started bubbling, now I dont have to go rent one when issues arise
