Need More Power In My 95 f150 5.8 liter
Want so more power in my truck. What should I put on it?
Gears might be your best move, what does it have now and what size tires are on it.?
Pull the spout connector out and bump the base timing up a couple of degrees. That lil mod is noticeable and free.
Careful with gears. I changed mine from 3.55 to 4.10's and it didn't like the change at low speeds when you nailed the go pedal. Changing the stock stamped rockers to 1.7 full rollers will net you some power and free up the friction by replacing the sled fulcrums to roller trunions.. Shorty headers will help some too. And these are pretty easy to upgrade to a 3" single exhaust. Going to a K&N air filter and removing the silencer from the air box will help too
More power
Depending on the $$ , better heads and stroker short block ! . I am building a stroker 351 /385 ci . Dougs tri-y long tubes , and a small ish roller cam .
