Truck goes in Monday for lots of warranty stuff...... UPDATE.
I made an appointment to drop off my truck on Monday. Here is the list of things that they are supposed to look at and fix.
The service guy jumped in my truck with me and acknowledged that he heard both ticking noises and the rattle/squeaky doors. So that may be sort of a positive. At least they cant say they cant replicate it when their guy heard it. * Ticking noise when I get on it to a vehicle on the freeway. * Ticking/rattle noise (different from above) coming from same area * Rattling squeaky doors * Passenger side door front bulging out a little. Doesnt align. * Dash trim around cluster not right. * Hood alignment off. Big gap one side, no gap the other. * Paint flaw in hood. Like a tiny bug landed on it when they sprayed. * Heater block plug thingy recall. Fleet manager told me a new recall cam out today on the downshifter..? Cant find anything on that. So I need a truck for weekend band gigs. With all this stuff that needs fixing, at what point do they give me a truck to do my job? I am single and have no other vehicles available. I'm hoping this doesnt turn into a drawn out fight to get it fixed right. I'd rather not go lemon law but will if it has to be. |
Originally Posted by 77mmbass
(Post 18702013)
I havent seen anything either, nor could I find anything on the webz. He said he hasn't read up on it yet but just got the alert about 30 minutes before I saw him.
So it may be nothin.... he may be wrong about the model of the vehicle. |
(Post 18702027)
How many miles on the truck?
I only have 1k on mine but have a tick that I haven't been able to pinpoint. Same sound as the rest of the plastic dash etc. make when it's hot or first driven, only this one is more consistent. Im planning to get some more miles on it incase additional things start to surface. I found a paint flaw like you're describing too, tiny one on the door edge, almost not noticeable and another more noticeable booger on the roof. Fortunately because the size of one and location of the other I'm going to leave em and avoid the possibility of making things worse. Take some before and after pics if you can. |
(Post 18702013)
Still, I hope they get them all and get them all right. Good luck. |
Originally Posted by edjunior
(Post 18702048)
I don't believe the lemon law works for your multiple issues. It is more for the same issue, or issues, being fixed multiple times. I could be wrong, and it could be for a shopping list of issues also, but all I have seen and heard before is multiple attempts to fix a single issue with no resolution.
Still, I hope they get them all and get them all right. Good luck. That's where the lemons happen. |
Originally Posted by ForCal
(Post 18702046)
(Post 18702285)
My truck had the ticking noise at 100 miles. It now has 10500 miles and has the same issues
Post up how that goes. It would be interesting to see stuff like the dash trim, door bulging, hood alignment before and after. |
I saw a video recently talking about a tapping/rattling on the firewall area, turned out to be the trans filler tube I think. Might be worth looking at if that's the area the noise is coming from.
When I took mine in for death wobble I insisted on a loaner. The service advisor balked but the service manager got one lined up for me. They kept the truck 10 days, I drove the wheels off the loaner.
mine just went in for antifreeze leak - needs the t replaced, both running boards are showing rust bubbles, and the batteries are leaking causing corrosion on the hold downs, and the heater cord recall.
17 f350- dealer told me that they would take pics and send in but ford will likely not replace the boards? I told him we will cross that bridge in a bit but I expected them to be replaces. |
^^^^I've had both running boards replaced on my 17 F250 for blistering chrome. Driver's side after one winter...pass side after 2 winters. I'm still in my 36/36000 warranty period. Zero issue with getting them done. All 4 PVD wheels were replaced at the same time. SA took pictures and parts were ordered while I was there for a Works oil change.
dealer just called and said the running boards are cosmetic and not covered under warranty-
jokes. |
Originally Posted by Gwilkrrs
(Post 18703149)
jokes. |
