EEC-IV or EEC-V?
I have a 1997 F350 with a 460 gas engine. It is an old U-Haul. Because it is over 10,000 GVW, they got around the OBD2 requirements. I don't know if it is an EEC-IV or EEC-V system. From what I've read, EEC-IV codes can be accessed by jumping wires in the EEC. EEC-V requires a scanner. Cover of EEC says only "EEC".
I could be wrong but I think EEC IV has a 64 pin connector for the ECU and EEC V has a 128 pin connector.
Originally Posted by BobQPublic
(Post 18697368)
The cover which says EEC is over the test port(?) for the EEC, on the driver's sidewall of the engine compartment.
Then it's an EEC-IV system. An EEC-V system would have the diagnostic connector under the dash near the steering column.
Thank you!
