90 460 coolant bypass hose
just picked up this f250. needs coolant hoses badly. there is a bypass hose next to the lower coolant inlet hose. same diameter. very sharp 90 to a very close inlet. is there a way to install a new hose without removing the water pump? tried warming new hose in the sun and using soap on the inside to make it slip on easier. no luck. other ideas/shortcuts? perhaps soaking hose in hot water? Many thanks for your input. Thanks...Roger
Silicone spray on the inside of the hose.
so far i've tried first soap then vasoline. both helped but still no go.
