What oil in Transfer Case ???
I just saw a video that was warning against using Mercon V in the transfer case ~ what's the story ~ is that BS or ???
What about using it in the Tranny ??? Thanks Rich |
Originally Posted by Richard S
(Post 18686422)
What about using it in the Tranny ??? Thanks Rich Ford now says Mercon LV is good for transfer cases. Transmission depends on which one you have. |
Greetings ~ 2001 F150 ~ Tranny FR70W ~ me thinking ```
Mercon LV and I here XL12 ~ they both OK ??? Have to get this from Ford ???
(Post 18690004)
Go read this thread in its entirety, including the linked pages Just had this discussion less than two months ago.
https://www.ford-trucks.com/forums/1...l#post18608438 |
Ok ~ thanks, I'll have a look ```
What about Valvoline Transfer case fluid ~ can that be used in F150 2001 ???
(Post 18752935)
Valvoline says it meets Motorcraft specks ~ is it being use by F 150 owners ```
Undoubtedly since that's what they'd put into the unit at the Valvoline Instant Oil change locations.
If Valvoline says it meets the requirements, then why are you questioning them? |
For one; which motorcraft specs ?
Originally Posted by geekwithoutacause
(Post 18753364)
I'd stick with the motorcraft stuff.
I used Motorcraft Mercon LV in the transfer case ~ after I put it in the TC ~ I found I had two bottles on the shelf in the garage ```
I'm thinking of getting a electric pump to remove the oil from the engine and transmission ~ have you used one ``` |
