Airbags w/ PMF blocks
I leveled my 2019 F350 4x4 using the PMF blocks and now I want to put airlift bags on it. Do you know if I should still use the bags that are supposed to fit the factory suspension (#88399)? Are there any changes that need to be made do to the shorter blocks?
Depends, did you get the blocks with the bump stop tangs? If you have smaller blocks, then you'll probably want to get Daystar cradles and some air bag spacers to make up the difference. I would go with the Firestone or Torque airbags since they go over the springs and not the airlift type that goes over the tang.
Anyone have a preference between the firestone and torque bags
What is a PMF block?
is your 360 single or dual? |
Originally Posted by porthole
(Post 18688563)
is your 360 single or dual? not sure they make them for the 360 though ;-) |
Originally Posted by Ryanwolf
(Post 18687896)
