1992. 460 F250 Manifold/carb switch
I was given a an Elderbrock intake manifold and Holly 4 barrel carb for a 460. My question is how hard and what would be needed to switch out the fuel injection to a carb and what installation problems may occur.?. Any help with this would be appreciated.
Manifold /carb switch
Thanks for the response. Standard trans. Im going to go for it.
Manifold carb switch
Ok , one last question I hope. The Edelbrock manifold I want to use is an older type manifold. My engine is a 1992. My question is when I remove the fuel injection will ANY 460 intake work.Thanks for the help.
I'm curious about your question.
I know that 460's had different heads for EFI. Someone else can chime in. I know Diesel Brad is well versed on the 460's and several other members. You may want to do a search. Good luck! |
Originally Posted by Rotorpilot
(Post 18664363)
http://www.pricemotorsport.com/html/body_ca-460efi.html |
^^^^ Exactly what RLA2005 said!
I forgot to include you RLA2005. Thanks for clearing up his question. |
