Wheel runout, tank mods and other stuff
After losing two weekends due to being sick I am getting ready to drop the tank tomorrow since when I did the Hutch mod I re-used my old pickup foot, that was 9 years ago so I decided to install a fresh one. Meanwhile I got all the wheels off the ground and fitted up a dial indicator to check lateral runout on the wheels after my bone crushing pothole incident in Mexico last month. Little to no runout, worst was driver's front at .006". So I think I'm OK on that. I read somewhere that up to .050 was acceptable. On to the tank tomorrow, then the Racor install. By the way, is it OK to re-use the fuel injection clamps from the Hutch mod? I ordered new ones from Amazon but not sure when they will get here.
Mind telling what they are called on Amazon? No one seems to know. I have reused in the past with no problems.
Originally Posted by BBslider001
(Post 18659130)
I'd reuse the injection clamps as long as they are not distorted.
Really glad to hear the runout was so good after that Mexican crater. Ford tough! |
I don't know of any reason not to use them as long as they're not damaged. Since you're changing the foot, I hope it's not a Dorman. I installed one a short time back and it fell apart so I suggest sticking with OE. I've put a lot of unconventional stuff in my fuel tank so initially I thought maybe I had something to do with its early demise, but I looked at reviews on Amazon and discovered that many others have had the same problem. The material swells allowing the valve to fall out so you suck air kinda like when the foot is broken, the screen also falls out. OE on amazon is under $40, dealer price is just under $60. I didn't want to have it disabled for 2 days waiting for the part so I bit the $60 bullet.
Yeah... unless dropping the tank gives you a thrill, I'd put good stuff in there. As long as the clamps are fuel injector clamps, keep on using them. If they're helical clamps, I'd trade them in for fuel injector clamps.
The clamps turned out to be ordinary worm clamps so I will used the new injection clamps that showed up yesterday. The foot was indeed broken off and the new one is OEM from Clay. Probably going to replace the lines to the pump today simply because I will not be able to remove it from the barbs on my Baldwin filter base and I am switching to the Racor PS-120 today. Why does everyone use 3/8" hose? Wouldn't 5/16" fit tighter and isn't it the OEM size? Maybe 5/16" won't fit onto the barbed fittings on the filter base? Bone stock here no need for big fuel.
Use 5/16 from racor to pump, 3/8 from racor to tank.
Originally Posted by CousinCarl
(Post 18660881)
Originally Posted by Tugly
(Post 18661107)
Also... use 45-degree fittings on the Racor instead of 90-degree.
(Post 18660881)
Originally Posted by bigb56
(Post 18661186)
What's the reason? Not sure I have enough line to do that. (see next post)
(Post 18662268)
It actually reduces the amount of tubing needed, but that's not the reason I did it. Before this mod, there were no hard turns in the suction line, and I find no reason to introduce them. I had issues with the fuel pressure dipping more than I want it to, and changing the fittings to 45s didn't make a huge difference - but it got me in the comfort zone.
I also used straight fittings into and out of the RACOR PS-120 filter between tank and pump when doing the Hutch/Harpoon mod. Not sure why a 90 or a 45 would be an advantage?
I also did not use the foot. I thought it was just something that would fall apart, again, inside the tank. Ended up just running the pickup down close to the bottom of the tank. |
If your system works straight, that's ideal. I mounted mine so high on the frame that used angled fittings.
Here's an earlier photo before I swapped to 45 degree fittings: https://cimg8.ibsrv.net/gimg/www.for...904d54063b.jpg |
