Ford Truck Enthusiasts Forums
-   1961 - 1966 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum40/)
-   -   Hub cap paint codes (https://www.ford-trucks.com/forums/1583543-hub-cap-paint-codes.html)
Mearntain 05-17-2019 10:39 AM
Hub cap paint codes
What are the proper paint codes for '64 hub caps? Having trouble finding this.
I would guess the white is a Wimbledon White, but not completely sure. No idea what color grey it is though. Thanks.
ibuzzard 05-17-2019 10:52 AM
The silver is just called “Argent”, I think. Not sure of the red used for the lettering, but someone’s gonna be by to let you know . . .
Mearntain 05-17-2019 10:58 AM
Thanks ibuzzard. Mines a 64, I believe the white lettering was factory paint for that year. Hopefully someone can correct me if I'm wrong.
TA455HO 05-17-2019 02:00 PM
Here's some NOS ones on ebay. Lettering was not white in 1964.
https://www.ebay.com/itm/NOS-1961-64...sAAOSw3FBbKGf8
https://www.ebay.com/itm/61-62-63-64...0AAOSwB0hcnTxx
Mearntain 05-17-2019 04:23 PM
https://cimg3.ibsrv.net/gimg/www.for...74a00c334e.jpg
This is what's on the truck right now, and I'm pretty sure I remember the person I got the truck from (who was the original owner) that they were the factory hubs still, I could be remembering wrong though. If the ones I currently have truly aren't the factory ones for that year, anyone know what year these white colored ones are from?
ibuzzard 05-17-2019 04:29 PM
Caps are correct, the white painted lettering is not.
tripleframe 05-17-2019 08:34 PM
https://cimg5.ibsrv.net/gimg/www.for...f8281b8a75.jpg
https://cimg4.ibsrv.net/gimg/www.for...9dae96b7d6.jpg
First photo, pair of '66 F 250, with correct boxes and part numbers, they are argent silver with red letters. Second photo, a set of nos F 250's, however, note the three alumunim- gray color caps are '61 thru '65,with correct boxes and part numbers, but the red letter cap is a '66 , it is argent silver, not aluminum- gray, like the other three..., So, the aluminum gray is the correct color for a '64. Not aware of any codes, but I would color match to a nos cap or very nice original cap.
Mearntain 05-18-2019 11:13 AM
Sounds good, thanks yall. If red was the stock color, that's what I want to go with. Just need to find out what color red now.
NumberDummy 05-18-2019 04:07 PM
COLOR code J = 1961/66 Rangoon Red.
Mearntain 05-18-2019 06:03 PM
Thanks a ton! Do you by chance know what year the white paint was stock for? I know I've seen it somewhere, but cant find it now.
instig8r63 05-18-2019 06:59 PM
$600 for hub caps???:-missingt
NumberDummy 05-18-2019 07:23 PM
COLOR code M: 1961/63 Corinthian White // 1964/72 = Wimbledon White.
There was also COLOR code C = 1964/72 Pure White which is a bright white. Wimbledon is an off white, Corinthian was another shade of bright white.
1964/66 hub caps (some were painted argent), grilles, bumpers were painted Wimbledon White, but this info came from FTE members. There's no FoMoCo source for this info that I'm aware of.
Mearntain 05-18-2019 09:12 PM
I'm almost thinking pure white is the original colors in the picture of the hub caps I posted higher up in the thread. I do have the original bumpers for the truck, which I plan to repaint with the rest of the truck back to factory colors, which are Wimbledon white.
TA455HO 05-18-2019 11:04 PM
Mearntain, I believe someone added the white to that cap in your picture. As TripleFrame pointed out in 1964 the caps were just one solid argent gray with no other colors (red or white). So if you are going for the original look it would be the caps you have in the gray but no white. You can tell the white was added especially because of the white on every other low spot around the outer edge. Ford didn't do that.
TA455HO 05-18-2019 11:15 PM
Here's the entry for 1964.
https://i636.photobucket.com/albums/...psge8idwvs.jpg
