Sunroof Solution to noise / sticking - Lube it
With the 90 degree weather last week I started using my sunroof again. Only issue is the damn thing wouldnt open. After finally using the vent button to break the seal, it would then open. Looking at all of the seals and tracks they where bone dry. The heat was causing the seals to basically glue themselves to the glass. So I looked up the sunroof service in the Ford factory service manual and it called for lubricating the seals and tracks with Krytox. I ordered it from amazon applied it and now the sunroof is quite, opens smooth as glass.
I have been using 3M brand Silicone Spray (DRY) and it is working like a champ. Not sure what the Krytox formulation is, but I agree that the right lube has eliminated all of the popping and sticking I used to have and I am no longer hesitant to open the sunroof!
This is a great piece of information. I personally believe this piece of maintenance is overlooked by most owners and many dealers. Many are afraid of using their panoramic sunroofs but I keep the seals and rails lubricated and don’t think twice about opening it if the weather is nice
I was planning on using some silicone grease to lube mine when I receive my truck. I’ve used this grease (scuba diver o-ring grease) to lube the window track rubber on 20+ year vehicles with great success. I’d wager that this “sticking” is the main cause of broken sunroof tracks.
Originally Posted by Adam R
(Post 18655411)
Sticking is 100% the reason the roof breaks, or 99.9%.
well I am glad there is a specific ford recommendation. I just ordered it.
when I had my 2010 I had a problem with mirrors sticking and rear window sticking...I lubed them with some neutral spray lube...it made the problem worse as the lube acted like glue. |
Originally Posted by GrantGunderson
(Post 18655453)
I would imagine that teflon or silicon will work as well. However there is quite a bit of documentation online on various vehicle forums warning against using silicone on sunroofs and Krytox specifically states that it does not include silicone so I went with the mfg's recomendation. Plus a little goes a very long way.
Which seals are you applying this too? The seal all around the glass or just the big seal between the two panes of glass? I wish this wasnt $30 for 1.9fl oz but I really dont like the alternative so I will pony up as my sunroof likes to pop even after being vented. It usually takes 2 pushes of the open button for the glass to move rearward.
Originally Posted by nomad_archer
(Post 18656469)
Originally Posted by dnoel
(Post 18656538)
Worse yet, it's for 1 oz. of fluid. 1.9 is the weight.
Wish I saw this a year ago...Mine is broke and had to pay $100 to get it closed (was stuck open)
did it specifically call for that version of krytox? as there are a number of krytox products..
(Post 18656469)
Originally Posted by Xwild
(Post 18656861)
