1999 EXPEDITION AWD
Hello, New to forum have question concerning awd bypass, I was wandering if pulling the fuse do I still have to worry about tire dimensions like I do if I don't bypass as in keeping the tires all within 3/32 of each other as well as tread pattern. Thanks as i have 8/32 in back and need 2 front tires asap, 255/70/16
What about your ABS?
Not sure of he abs system and if that would effect the tires size
Originally Posted by chumley1999
(Post 18653193)
Except that the ABS might kick in while braking if there is too much variation in tire demensions.
I’m not sure on how much variation you can get away with. I can’t remember, but does the ‘99 have a 2H position on the selector switch? |
99 does not have 2h, if it did he wouldn’t be pulling the fuse.
Originally Posted by pdqford
(Post 18654487)
Except that the ABS might kick in while braking if there is too much variation in tire dimensions.
Okay. What your saying is that the wheel tone ring signal must go to zero in order for the ABS to kick in while braking. I didn’t know that. Thanks for the correction.
(Post 18656048)
https://cimg7.ibsrv.net/gimg/www.for...a510026fbb.jpg |
