1999-2007 Super Duty Stock Tow Mirrors: What TT Mirrors Came on Which Truck?
First off I'd like to begin by mentioning this is my first time posting to the FTE forum despite actively visiting it for several years.
To begin, (obligatory forum post apology) if this is the wrong place in the forum for this to be posted, sorry. It's my first day here. Some backstory: I own a 2007 XL Ford F250. Being an XL it has non-powered mirrors--no heated glass and no turn signal indicators either. I've looked high and low on both this and other forums but can't seem to find a solid answer to what mirrors came with which year trucks/trim packages. To simplify, while searching online for the original trailer tow mirrors that came with these trucks (the rounded ones with two separate pieces of glass) I've so far found four different kinds: 1. No power anything, fully manual. 2. Power adjustable ONLY. 3. Power adjustable with heated glass. 4. Power adjustable with heated glass and turn signal + running lights. What I'm trying to find out is which mirrors came with which year trucks and trims. With my truck being an XL I have the 1st style of mirrors I listed. However, I've looked at several 7.3 Ford F250s of friends and coworkers that have powered towing mirrors but no heat symbol on the glass. Then when looking on eBay, I came across powered tow mirrors WITH heated glass but no turn signal switch backs. But I can't recall ever noticing the heated glass symbol on the powered (but no turn signal light style) mirrors on the many '99-07 F250 & 350 trucks I've driven. In other, simpler words, what trims/years (99-07 super duty) came with just power heated tow mirrors without the turn signal lights in them? To put it even simpler (and sneak in another question) what style of OEM tow mirrors came stock on years (99-07) and trim levels (XL/XLT/LARIAT)? My basic understanding gleaned from various forum postings and my own empirical evidence having been around these trucks for a looong time is the 7.3 XLs came with the non-powered (no heat, power adjust, or turn signal/running light) TT mirrors, the 7.3 XLTs came with power adjust TT mirrors,and the 7.3 Lariats came with power adjustable and heated TT mirrors (again, no lights though). Then, the 6.0 XLs came with non-powered (no heat, power adjust, or turn signal/running light) mirrors, and both the 6.0 XLTs and Lariats came with power adjustable TT mirrors with heated glass and the turn signal/running light switch backs. Am I even close to being right or am I totally off the mark? I really apologize if this post comes across as being pedantic, but I'm a real stickler when it comes to nailing down what the stock configuration of these trucks were, especially when you're the third or fourth owner down the line and would like to return the truck to how it was ordered and configured when it rolled off the dealership lot. If anyone would be so kind as to take the time and clarify it would be greatly appreciated and put this little conundrum behind me. Of course I did trying speaking to several Ford parts departments on the matter but got conflicting info, and that was on the good days when the service department actually even had a clue of what I was asking. Here's hoping at least one person is able to point me in the right direction. It doesn't help Ford has pulled almost all the literature (spec sheets, brochures, trim comparisons) for the 99-07 Super Dutys from their website as of late. P.S. I've added pictures as a reply to this thread, in an effort to make this easier to sort out. |
https://cimg0.ibsrv.net/gimg/www.for...cf1af12bd9.jpg
1) No power adjust, heat, or turn signal. https://cimg5.ibsrv.net/gimg/www.for...61b7c9419c.jpg 2) Power adjust ONLY. https://cimg6.ibsrv.net/gimg/www.for...21d990f831.jpg 3) Power adjust w/ heat. NO turn signal. https://cimg3.ibsrv.net/gimg/www.for...6152360358.jpg 4) Power adjust w/heat & turn signal indicators. |
In an effort to "bump" this thread, but also do so in a productive manner, I was doing some more digging this evening and just happened to find something that sheds just a little more light on the situation:
According to this post: Super Duty's from 99-02 (if equipped) are power only - NON-lit, and NON-heated. Starting in 03 (if equipped) they came pre-wired for power, lights & heat. If you have a 99-02 you can use the stock pre-wired power wires to run the mirror adjustments. And you can tap into other wires for directional and heat feeds. Then it all changed in 03/04 when the lighted mirrors came out. Barring the XL trim 6.0s, the XLTs and Lariat 6.0s came with the power adjust/heat/signal mirrors.... but you could have also gotten JUST the power adjustable/heat TT mirrors (but no signals) to save some $. Does this sound right? Anyone want to chime in on what your truck (what year and trim) came with for TT mirrors? |
You also have to factor in the various "convenience" or "safety" packages over those years that would include a different model of them, and even those were probably different among the 2,3,4,550 models.
I know my 06 250 xl has the bare bones model. Many people have swapped them with the later ( more squared) version. |
That's something I've definitely considered and noticed on the many different trucks I've driven and seen over the years. I'm just trying to look for a general rule-of-thumb, so to speak. E.g., All of the XLT-Lariat 2003-07 6.0 F250s and F350s I've looked at, generally speaking, came with the tow mirrors with heat and turn signals.
That seems to confirm what I've read in several other posts mentioning that the lighted mirrors weren't introduced until 2003 (see bold & underlined text): F-250/350 New for 2003
Still not totally sure and appreciate anybody who takes the time to chime in, even if you just reply with just your truck year & trim and the style TT mirrors your Super Duty came with. Thanks! |
I had a 2004 F250 XLT 6 speed manual that had none of the above. It had just normal small mirrors. Always annoyed me that they didn't put big mirrors on such a large truck.
Originally Posted by ESV
(Post 18651456)
(Post 18651456)
The truck in my signature is a 2007 F250XL and it came with power adjustable heated tow mirrors with turn signals and marker lights.
Originally Posted by Mark G1
(Post 18652058)
Also, dumb question but I take it your XL has the mirror power adjust control on the driver's door? |
I bought the truck used a couple of years ago and they came with it. Yes, the drivers door has the power controls. I have the factory sheet on the truck somewhere. I will see if I can find it to see if these were original. I believe they were as no other upgrades were done to the truck.
EDIT: My truck does have the factory tow package with the Trailer Brake Controller. I guess it's possible the mirrors were part of that package. |
My 2007 came with the full blown mirrors. When I ordered it I thought it was part of the heavy duty towing package.
It was definitely not a separate line item that I remember. |
Originally Posted by super 6.8
(Post 18656636)
(Post 18656259)
https://cimg2.ibsrv.net/gimg/www.for...d7369da6c.jpeg
https://cimg4.ibsrv.net/gimg/www.for...78444d296.jpeg https://cimg7.ibsrv.net/gimg/www.for...133b79375.jpeg Yes, I have power windows and door locks. It does not have remote keyless entry. |
