Ford Truck Enthusiasts Forums
-   Pre-Power Stroke Diesel (7.3L IDI & 6.9L) (https://www.ford-trucks.com/forums/forum117/)
-   -   Just checking... IP gear can't jump teeth inside the housing, right? (https://www.ford-trucks.com/forums/1580515-just-checking-ip-gear-cant-jump-teeth-inside-the-housing-right.html)
119er 04-20-2019 06:54 PM
So I have my pump and injectors off being rebuilt at the moment. I was installing new GP's and decided to clean the bores and threads on both the GP and injector bores. As I blew air into the one of the bores, the engine rolled over and the pump gear moved, obviously. I lined my witness marks back up, but it shouldn't matter anyway, right? Gear rotated 20 degrees or so counterclockwise. Just checking that it can't somehow jump time.
hairyboxnoogle 04-21-2019 03:12 AM
Nope. I tried it on mine when i was putting it together just to see if you could. Furthermore, you have gravity on your side in this situation.
119er 04-21-2019 10:44 AM
Thanks for the reassurance. I was positive that it couldn't, but I am making a lot of changes at once. Should I have any issues getting up and running, I didn't want that in the back of my mind.
hairyboxnoogle 04-22-2019 09:37 PM
Other than a little air from having the pump off, should roar to life just fine.
