92' and newer eletric speedometer swap to older
https://cimg9.ibsrv.net/gimg/www.for...4328ea163d.jpg
https://cimg0.ibsrv.net/gimg/www.for...c5b6ef984d.jpg https://cimg1.ibsrv.net/gimg/www.for...c1b2fe4912.jpg I just did a ZF5 swap to my 88' F350...however, it was a 92 and newer Zf5 speed without the speedometer port. Does anyone know how to wire in a en electric speedo from a newer truck(92-97)??? Much appreciated! |
I found this link....it might apply to your speedo problem.
https://www.thedieselstop.com/forums...e-gear-149028/ |
3 Attachment(s)
Originally Posted by b1jetmech
(Post 18609253)
I just did a ZF5 swap to my 88' F350...however, it was a 92 and newer Zf5 speed without the speedometer port. Does anyone know how to wire in a en electric speedo from a newer truck(92-97)??? Much appreciated! That should do it. Images for wiring: Attachment 283572 Attachment 283573 Attachment 280347 / |
Originally Posted by subford
(Post 18609380)
Just tap into the ABS sensor wiring from the rear end under the dash at the ABS module. Then wire in both of the power wires and ground.
That should do it. Images for wiring: https://i.imgur.com/4cP3iKk.jpg https://i.imgur.com/CV32Mc1.jpg https://i.imgur.com/WYdLmIr.jpg / |
Here's a thread about how to do the swap: https://www.ford-trucks.com/forums/1...-issues-2.html
After getting the wiring figured out, you just have to cut up the old cluster to fit the 92+ speedo in place. |
