96 351w swap into 95 f150
I have a 95 f150 351w, I'm getting 20#'s fuel pressure with key on 30#'s at idle and just under 40#'s after removing vacuum line.
is this acceptable fuel pressure? as I have rebuilt and checked all fuel injectors replaced two fuel pressure regulators two fuel pumps and two fuel filters and it still wants to stall when I give it just a little throttle. when driving I can floor it and it will go faster but it takes forever. I have replaced map sensor, tbp sensor, iac valve sensor intake manifold temp sensor and any other sensor you can imagine, like o2. transmission checks out ok. can't find any vacuum leaks. alternator is putting out correct voltage and battery is at over 13 v. The timing is 10 degrees btdc. Because of the wiring differences between the 96 351w and the 95 and the condition of the egr tubing, I did a complete egr delete thinking to save money. Can't see how that would cause the stall issue though?The only thing I can think of is maybe an exorcist! Also had the instrument cluster recalibrated. Any advice is greatly appreciated. Thanks ;-p still smiling just scratching my head! |
Yes that fuel pressure is fine.
Did you use the '96 engine wiring harness? |
No sir , I kept everything on the 95 f150. The only sensor I had to put in the 96 engine was the air charge temp. sensor.
So you deleted the EGR which means the valve and tube but how did you plug the exhaust and intake?
Did you remove the distributor at any time? If so did you set #1 piston at TDC before reinstalling the dizzy? |
I used a plug fitting from a old hydraulic pump to plug the exhaust manifold, and yes I did set #1 piston tdc before stabbing the distributer back in.
it's timed to factory spec's 10degrees BTDC. the engine starts and idles perfectly, it's when I start to give it gas it want's to stall. So I feather the pedal it recovers and will drive but it wont coast or stop without stalling. When I floor it, it goes, but it acts like I'm dragging a tree behind me. Is it possible that I need to " chip " it and have it recalibrated or is this truck too old for that? |
What did you do to plug the intake where the EGR valve attaches?
I purchased a milled egr plate that bolts to the plenum where the egr valve used to go.
OK lets go back to fuel pressure for a moment. The numbers you posted originally looked good but does it maintain 32-40psi when the engine is under load.. or even when the throttle is goosed with the truck sitting in park? The pressure should never drop below 32psi.. ever, any throttle opening should send it higher.
Just hooked up fuel pressure gauge and key on 20# , running 30# high rpm's still 30#
Originally Posted by omallyman
(Post 18606845)
it still wants to stall when I give it just a little throttle. can't find any vacuum leaks.
(Post 18606845)
Ok, the 96 had a plastic canister and the 95 had a soup can. it was removed with the egr system.
https://cimg6.ibsrv.net/gimg/www.for...e8dea9daa9.jpg |
Ok you went a step too far with that, the HVAC controls will also do funky things without a vacuum resovoir. Is the white line that goes into the cab through the firewall near the blower motor connected straight to manifold vacuum now?
What motor was in this truck before the 5.8 swap? |
