How to determine if rear end has limited slip differential
So I'm about to change the fluid in my rear differential. It's a 2000 F250 Super Duty 4x4. How do I know if it's a limited slip differential as if it is I am supposed to add an additive.
Thanks |
You can check the door tag. The axle will identify if limited slip. Not sure about 2005 but my 2015 shows 3L for the axle code. L identifying a limited slip.
Or you can jack up one rear wheel and try to turn it. If it turns freely, it is not limited slip. |
