Front bump stops
Do the coil spring trucks (2005-2007) have front bump stops? I’m having trouble finding them if they do. I’m thinking about adding a dual steering stabilizer and Superlift says I may need to “slightly limit the compression travel with bump stops”. I assumed I’d need to get taller bump stops. Now I can’t find that the truck has ever them or that anybody makes an aftermarket version that’s taller. Any advice? Thanks.
They do.....drivers side of my stock 2006 F350....view from bith sides of driver side tire
https://cimg2.ibsrv.net/gimg/www.for...ef1ec2d5e.jpeg https://cimg3.ibsrv.net/gimg/www.for...f31e3dfe0.jpeg |
Originally Posted by seville009
(Post 18594985)
You are wrong
I’m the original owner.....it’s stock as I said it bumps into the axle if it comes up too much, hence “bump stop” |
Well (hat in hand) I stand corrected! Here’s a picture of where mine used to be. That flat surface just below is it’s landing pad. It’s maybe 6x6” or so, plenty of space to do a good job. There’s another similar one (equally trashed) on the other side. So now that you’ve squared me away (and helped greatly, thanks) the question changes: why is there not a readily available replacement part for this? Nobody I’ve found thus far make any front bump stop for the coil springed trucks. The 99-04 (leaf spring) bump stops are made by several companies. Have I missed something?
https://cimg6.ibsrv.net/gimg/www.for...fef595fcb.jpeg |
Search for Timbren ses suspension parts.....I use them in the rear of my truck...think they also make them for the front for snowplows etc.
Thanks! I looked at their stuff. Its better quality (and more cost) than I was looking for, but it may be just what I need. My front end can tend to bounce pretty hard on big bumps at interstate speeds. This seems like it’d dampen that some. It’s not obvious which one I should use. I’ve emailed their sales team and I’ll hopefully hear something tomorrow. I’ll update.
For what it’s worth, based on the condition shown in the pictures I don’t think my bump stops have ever “hit”, even with about 1,000 lbs of v plow and wings hanging off the front (I have 6,000 lb springs).
I’ve never done heavy duty off roading though. I wouldn’t worry too much about not having them. If you hear alot of banging, then put some on |
Originally Posted by DieselVol
(Post 18597597)
They contacted me this morning and recommended the FF350SDC. I have a set ordered. Based on what the company claims, the bump stops may help with some of the steering problems I’m having. I’ll try them out and see what problems are left to fix. Thanks for the help.
Tasca Ford lists them for under $7ea, they just pop into that metal cup, those tabs hold it in. There's 2" spacers available that lower the whole unit if you want to limit travel. https://www.tascaparts.com/oem-parts...wtdjgtZGllc2Vs https://cimg3.ibsrv.net/gimg/www.for...051ee8351f.jpg |
Originally Posted by speedfreak78
(Post 18598434)
Bump stops don't do anything unless your overloading the suspension or hitting large whoop-de-dos at speed, you need to compresses the springs a fair amount before they hit. They certainly don't have any affect on the steering during normal driving.
(Post 18598459)
Agree with all of that and think it’s unlikely to fix my issue, with the exception of some rough spots on my regular interstate runs that cause some significant compression of the front end. The product I have ordered is in constant contact, top to bottom, and can act to dampen that bounce, where as the stock bump stop only acts to stop extreme compressions. I often get bump steer in moderate compressions. Hopefully, this will reduce this problem. I agree that it may not.
Look at Super Springs too. I put them on the rear of my truck to help manage the load of my in-bed truck camper. Work great. You can read the story below in my signature.
(Post 18598477)
Bump steer is caused by a difference in geometry between the suspension travel and steering linkage travel, or worn parts. If you're compressing your suspension that much on highway driving, you probably need new shocks, not longer bumps. Would have probably cost less than those things that are now going to mask the real issue.
