Exhaust upgrade 292 yblock F100
https://cimg2.ibsrv.net/gimg/www.for...acc379ddb8.jpg
Here is my current setup As you can see, I have the original stock exhaust setup. I want to convert to headers and some nice aggressive mufflers. Anyone know of headers that will fit bolt-on? Looks like I'm going to have trouble on driver's side. I guess that's why they did the exhaust in this weird way to start with. I don't want to break the bank. Not looking for show, but functionality. |
Originally Posted by Knockonwood
(Post 18588075)
Y-blocks are a bit different with the upsweep on the manifolds and crossover tube. Keep your eye peeled for Rams horn manifolds that will work with your engine. Some buses and things like that had them. Make sure the bolt pattern is correct though, the Lincoln manifolds look similar but will not work with our 292s. Dual exhaust sounds great, run it all the way back to the bumper, use cherry bombs or steel pacs, whatever you like. |
There should be no trouble at all if you order headers for a truck. Red's, Sanderson, Speedway / Patriot are a few of your options. The Speedway / Patriot headers have issues with the crossmember on '61-'64.
Complete
I replaced my stock exhaust with Patriot headers. (They required persuasion to fit, but a little propane torch and a big hammer later, they're in). I bolted on 3" Puple Hornies with turn downs. It is loud.
Here's a link to a video of it in action. |
"Let's start it up, see if Mom approves of this!"
VROOM! VROOM!! VROOM!!!" "Hahaha!!!" Sounds great. |
Originally Posted by Tedster9
(Post 18588689)
HOME Y And, yes, they are not cheap......But $350 is not all that bad considering what you're going to pay for anything new for anything newer. Headers might be slightly better but can be a LOT more money depending on what you buy, and the Rams horns will "look" MUCH better and look original. That video sounded GREAT and the smile on that kids face made it all worth it!! But I would still do the Rams Horns from Mummert. Wat ever you do, be sure to take a video and post it here!! Cheers, Rick |
Mummert rams horns are more like original inside the ports, which is good. The Speedway version has material protruding into the port because they made more room for a washer on the outside, I guess, so you cannot grind the protrusions away.
Originally Posted by HT32BSX115
(Post 18665783)
I wouldn't waste any money on old rusty ram-horn manifolds when you can buy new manufacture Rams horns!
(Post 18665913)
Well I suppose I should have added "if the price is right." I agree it makes no sense otherwise.
Before the new ones were available, I used to see rusty old Rams for sale on eBay for ridiculous prices. |
https://cimg0.ibsrv.net/gimg/www.for...e3c1749f8b.jpg
Sorry, a little late to the party. I originally had custom made headers on my truck. With a Volare front end you do run into issues. I guess with any type of headers you'll have issues. First one. Passenger side, needed to replace starter. Had to drop the header, no big deal how often will you be doing that. Second issue, Saginaw power steering gear box was leaking. your doing a lot of work just to get the gear box off. Now putting it all back requires two people. One working from top, the other working from below. Doable, but I also had a set of rams horns. So the rams were cleaned up, trued up then powder coated.I now have $500.00 ram horns. Best part if something needs to be replace, there's only one pipe, 5 bolts per side and you can get to everything. I now have a custom set of headers I don't need. The trade off was a cleaner engine bay and easy access to everything. |
How's it sound? Maybe a YT video would be helpful to us, hint hint
I put some long tube headers off of a ‘57 t bird on my ‘59 F250 with purple hornies with a 3” collecter to 2 1/4 outlet. No clearance issues, and way cheaper than new long tube headers.
https://cimg4.ibsrv.net/gimg/www.for...7f7a92fed.jpeg https://cimg6.ibsrv.net/gimg/www.for...92f3263e6.jpeg https://cimg7.ibsrv.net/gimg/www.for...656c107af.jpeg https://cimg9.ibsrv.net/gimg/www.for...f1d86a49a.jpeg And there is about a 5 1/2 inch clearance from the steering box. And I never had any trouble putting anything on. It all fit perfectly with no propane or hammers. |
That looks like a truck header to me. Long tube T-Bird headers require a more complicated tubing layout because it is a much tighter space to work within. They also have to be a bit shorter from the head flange to the outlet, which will not work in trucks.
Regardless, the tubing diameter looks bigger than usual. What is the diameter and any idea of the brand? |
Originally Posted by charliemccraney
(Post 18846641)
I flipped my manifolds so the crossover flanges were facing the rear.
https://cimg1.ibsrv.net/gimg/www.for...5d040ea622.jpg Blocked off the origional down tube flange and used the cross over flanges to fabricate new down tubes and dual exhaust. happy with the results... Upside is that it didnt cost a thing... just gotta be handy with a metal glue gun... |
