:-X06
Looks great |
10 Attachment(s)
Originally Posted by 78ShortBed-
(Post 18644171)
:-X06
Looks great Thanks! The passenger side pocket was a bit more work since the seam was crooked at the top. I rounded off an air chisel tip and used that to move the edge of the long panel over to where it should've been. Attachment 283406 Attachment 283407 After moving it over, still not perfect but much better than before. Attachment 283408 Patch made, determining the right spot to make the bend so the gap is even. Attachment 283409 Bent, fitted, and welded weld in. Attachment 283410 Attachment 283411 The front bed pockets were opened up to get back to flat metal, then were straightened, spot blasted to touch up missed areas of rust, primed, and welded shut. Attachment 283412 Attachment 283413 Attachment 283414 Attachment 283415 |
8 Attachment(s)
The second wheelwell came in so I started getting it ready to install. The shock notch was welded up first, then I had to narrow the mounting flange to clear the raised lip on the inner bedside.
I scribed a line on the patch, then trimmed with tin snips for a near-exact fit with no grinding needed. This saves grinding discs and makes less dust in the shop. Attachment 283398 Attachment 283399 Attachment 283400 Attachment 283401 Difference in flange width. Attachment 283402 Attachment 283403 Attachment 283404 Attachment 283405 |
6 Attachment(s)
I welded in the header panel using the original spot weld holes, but some of those were halfway off the edge of the panel so I used a copper spoon to keep the weld contained and the edge straight.
Attachment 283392 Attachment 283393 The upper seams weren't pretty from the factory and they won't really be seen once the truck is assembled. I welded them up and ground down the welds so that all of it would look decent once seam sealer is applied. Attachment 283394 Attachment 283395 Attachment 283396 Attachment 283397 |
Been 15 days since you posted anything. On vacation? :) Those welds on the front of the box were ugly. I walked in the day the body shop started to prep my box just as he started grinding those welds down. I said what are you doing? His response was this was scabbed together and I am going to fix them. I said leave them as they are that is a factory weld. But they are ugly he said. But they are original I said. They are still there.
6 Attachment(s)
Originally Posted by skidoorulz
(Post 18681131)
Still working at it, did some small detailing on the wheel opening flanges. I'm about as far as I can take the bed without having the bed floor ready to go in; I don't want to start correcting the overall shape of the bed sides until everything is welded in solid. The bed floor will be making a trip to Maryland to McCartney Paint and Custom (MP&C on a ton of forums) to correct the irregular bed floor stampings. I'm going to Connecticut to buy one of my old Conquest TSi's back and will be stopping in on the way to work on the bed floor. I've already sent a sample section for him to make dies for his Lennox reciprocating machine to replicate the existing stampings in the blank areas. The wheel opening flanges, before and after. Things like this only take a few minutes with a hammer and dolly and make the bodywork go much faster. The end result looks much better also. Attachment 283322 Attachment 283323 Attachment 283324 Attachment 283325 I stripped the doors yesterday, razor blade and DA sander on the outer skin and blasted the inner panel (no finished pics yet). Started by removing the glue residue with a wire brush since the blaster doesn't strip soft coatings as easily. Attachment 283326 Attachment 283327 |
Originally Posted by theastronaut
(Post 18682220)
3 Attachment(s)
Originally Posted by emeraldcoupe
(Post 18682344)
gotta post some pics of it, I love those twins. they are the only imports I really like. awesome little cars
Attachment 283317 Attachment 283318 Attachment 283319 |
(Post 18683962)
These are from back when I owned it. I sold it around four years ago and it's been garaged since then until recently. It had an accident with the driver side fender and headlight door that'll need to be repaired, but it still looks like this overall.
https://i.imgur.com/XrZuf4qh.jpg https://i.imgur.com/xUGhw9Mh.jpg https://i.imgur.com/fn07zF5h.jpg wow, VERY nice. how many miles? that's probably the cleanest one I've ever seen. |
(Post 18684185)
16 Attachment(s)
I''ve made a bit more progress, just haven't been posting. The hood, doors, and fenders are all stripped now. One fender is trashed too bad to fix, the other is in pretty good shape, both doors are pretty straight with the normal rust at the bottom edge, and the hood is really nice except the edge of the nose.
Attachment 283026 Attachment 283027 Attachment 283028 Attachment 283029 Attachment 283030 Attachment 283031 I also started the bodywork on the upper part of the bedsides. I'll wait to do the lower section once the bed floor is welded back in, it's too flimsy as-is. I always block the "flat" sections first, first the top and then the side, leaving the rolled area for last. The flats need to be established first before rounding the curved area. I stopped blocking as soon as I saw epoxy showing through, continuing to block will result in low spots. Attachment 283032 Attachment 283032 Once the flats are blocked straight I spray more guide coat on the flat areas then carefully block the curved section until it blends evenly into the flat areas. The guide coat shows how far you're blending the curve into the flats. Attachment 283033 Attachment 283034 Attachment 283035 All work up to this point is done with 80 grit on a 3/8" thick acrylic sanding block. The acrylic has a hard surface force the sandpaper to cut the high areas down quickly and 3/8" is stiff enough to not flex. 80 grit is aggressive enough to shape the surface without leaving excessively deep scratches. Once everything is shaped with 80 grit I clean the surface well and apply more guide coat, then block it again with 180 to prep for primer. This round of blocking will show if you blended the curves into the flats evenly. Attachment 283036 Attachment 283037 Attachment 283038 After spraying a couple coats of epoxy to seal the bodywork. You can see how straight the flats are, how crisp the edges are, and how evenly the curved areas blend into the flat areas. This will be further refined with polyester high build. Attachment 283039 Attachment 283040 |
7 Attachment(s)
Same process with polyester primer. Flats first, more guide coat, then curves blended into the flats.
Attachment 283019 Attachment 283020 Attachment 283021 Same approach with the rear corner, except with thinner/flexible acrylic blocks. Attachment 283022 Attachment 283023 Attachment 283024 Attachment 283025 |
Astronaut: Sent you a PM re driver door. Did you receive it? Jeff
Originally Posted by JefflovesF250s
(Post 18806118)
Looks great. I wish I had someone around with your skill to offer guidance. I stripped my 65 F100 (99.5% solid metal) and now realize bodywork is whole different animal than mechanical and electrical. I think this is the one I will never finish. I am in New Hampshire if you know any one that can help.
