1966 F100 Short Bed Styleside Metal/Body/Paint Work
13 Attachment(s)
I just started another '66 F100 short bed project at the shop, this time it'll be a mild custom. I'll only be doing the metal, body, and paint work instead of a full build like the last one ('66 F100 Stock Restoration).
I'll be fixing the rust, correcting the panel fit and gaps like the last truck, shaving some items on the dash, mocking up a Vintage Air evaporator, smoothing the firewall, adding spots for A/C vents, and painting the truck. Here is the truck. It seems to be pretty solid overall other than the bed floor and door bottoms; definitely better than the other truck we restored. Attachment 283736 Attachment 283737 Attachment 283738 Attachment 283739 Attachment 283740 Attachment 283741 Attachment 283742 Attachment 283743 Attachment 283744 Attachment 283745 Attachment 283746 Attachment 283747 Attachment 283748 |
10 Attachment(s)
11 Attachment(s)
Subscribed. Did someone add reverse lights?
You do have a nice starting point. Nice Kight Rider steering wheel
Are the clutch and brake pedal welded together? Glad you are back!
Sean |
This will be fun to watch. I was in competition with you when I was doing mine. Amature against professional kind of thing. :)
Cool, I'll follow along. I'm sure you'll get this one finished and I'll still be working on mine...
A great canvas to start on. I'll be doing similar on my dad's soon.
Originally Posted by KO1960
(Post 18577521)
Originally Posted by RangerMercMan
(Post 18577595)
Originally Posted by 1armbanditrrt
(Post 18577892)
Sean
Originally Posted by skidoorulz
(Post 18578140)
Originally Posted by cookster351
(Post 18578722)
Originally Posted by jjriley97
(Post 18578792)
4 Attachment(s)
First update. I took everything apart that wasn't needed to make it run. All of the small parts were bagged and labeled so reassembly will be easier. I'll drive it around to one of the rear shop stalls tomorrow and finish dissasembly.
Attachment 283705 Attachment 283706 Attachment 283707 Attachment 283708 |
2 Attachment(s)
Teardown is finished. I'll finish removing the seam sealer and start blasting pieces next week.
Attachment 283693 Attachment 283694 |
9 Attachment(s)
I have the bed floor and header panel out now, and have blasted around the peremeter to prepare for welding the new floor in. A 2008 Super Duty floor is the same dimensions so we ordered one to use, along with a new header panel and front sill from Carolina Classics. The rear sill isn't available so I'll have to repair and straighten it.
Attachment 283651 Attachment 283652 The seam sealer was difficut to remove by blasting so I used a dremel to cut it out. Attachment 283653 New floor and header. Attachment 283654 Attachment 283655 Edges blasted to prep for repair work and new panels. Attachment 283656 Attachment 283657 Attachment 283658 Attachment 283659 |
Going to be a nice one.
What was up with the red light on the radiator support. Volunteer fire dept? |
Originally Posted by 78ShortBed-
(Post 18593787)
