Painting door panels
The top part of my door panels on my 2013 Lariat are fading from the Arizona sun so what's the best type of paint to use.
Denny |
IMHO, Urethane with a catylist is the best in durability and ease of application...but you will need a respirator to spray this because it is very toxic.
You want a dye for plastic. Several makers, use a prep spray. Try Eastwood or Summit racing.
Originally Posted by beartracks
(Post 18588171)
Sourcing used panels is a lot easier and will look a lot better.
Originally Posted by Beechkid
(Post 18588283)
Completely agree!!!! I wasn't sure if the OP was referring to the plastic panels or the door itself.....
Denny |
Originally Posted by rvpuller
(Post 18588468)
Plastic door panels
Denny They also make a wash & promoter before you use the dye. Dave ---- |
(Post 18590605)
Only thing I have ever used is SEM products for this type of job.
They also make a wash & promoter before you use the dye. Dave ---- Denny |
Look up a company Called Dr. Vinyl in Omaha Neb. They are good and i've used them several times. I use to live there.
