Rough Idle Burning Fuel Rich
https://cimg4.ibsrv.net/gimg/www.for...696e0bd095.jpg
I need some help. I was out riding around and all of a sudden I started getting a real rough choppy idle and the truck is burning fuel real rich with a chader right around 1500 rpms and smoking the whole time. My fuel mileage went from 17.5 to about 13. I'm also getting a turbo bark now I'm assuming it is somehow connected. I thought fuel injector. However when I got home I scanned for codes and I got a ton and I don't know what's going on. I just put a new fuel pump in a few days ago and my fuel pressure is right around 70 psi with the blue spring update. Disregard the egr codes I'm deleted the trucks an 03 with head studs please help. Sorry I forgot to post my codes. |
You have three more injector codes and a fuel pump code. I would start at injectors and make sure your blue spring os seated correctly or you could cause high fuel pressure and blow o-rings off injectors. Since you just worked on the fuel pump I’d check my work again. |
Originally Posted by SmackDaddy
(Post 18539224)
It shouldn’t, your post mase it seem like you did the fuel pump and blue spring together. |
(Post 18539540)
I Also wanted to mention in the recent past probably within the last 6 months I noticed at random not necessarily a hot start or cold start the truck would do a crank no start. I'd turn the ignition off and try again and it would fire right up like normal. not shore if this would be related to a cam sensor or not or what would even cause this.
In the 7.3 world I know a cam sensor can cause all kinds of weird stuff. Including random no starts and weird idle. But never had to change one on a 6.0 before.
Originally Posted by varminthunter243
(Post 18540619)
I would bet so. Cheap enough part. I kept a cheap oreillys sensor in my glove box to get me home if it quit. And then I would order one from international and put it in. I'd imagine symptoms would be the same. But I'm sure some of the more experienced 6 liter guys will chime in and tell us for sure. I just figure it's an easy part to change and readily available locally usually.
(Post 18540646)
Something come to mind I remember about a year or so ago I had a code for cam shaft sensor however I had no symptoms other than the code. I cleared the codes and it never came back until now
No CKP Sensor code? |
Clear DTCs, drive it then scan again for DTCs. It might pop up.
(Post 18540858)
They can pop up out of nowhere. I think I remember someone telling me there are soft codes abd hard codes. Soft codes will come and go but hard codes will stay until you clear DTCs. |
