Ford Truck Enthusiasts Forums
-   Fifth Wheel & Gooseneck RV Towing (https://www.ford-trucks.com/forums/forum287/)
-   -   New '19 f250 moves around while towing (https://www.ford-trucks.com/forums/1575033-new-19-f250-moves-around-while-towing.html)
'65Ford 03-10-2019 05:19 PM
That's about the size of it. In the quest to be bigger and better, new light duty pickup trucks are so close to their class weight limit that my 2002 actually looks more capable on paper. Not to mention the bed of my 2002 is lower making it easier to load cargo and hitch a gooseneck or fiver. We've had our 5 ton fiver over much of the US and not felt wanting for power. So I don't get the new trucks sitting higher, having obscene power, and too heavy to be useful in their weight class. Less than 2000 lb payload in a 3/4 ton pickup weighing 8000+ lbs and 900+ lb ft of torque is absurd.
crewzer 03-10-2019 05:48 PM
Originally Posted by Wotf8 (Post 18531816)
That is what I was thinking, with the diesel crewcab 4x4 it makes it heavier and actually reduces the payload and max trailer weight.
Bingo... It’s a particular challenge for the F250 and its official GVWR and payload numbers. Take a look at some of the load labels and the associated trucks in this old thread:
https://www.ford-trucks.com/forums/1...r-sticker.html
Check this one as an extreme example:
https://www.ford-trucks.com/forums/1...l#post17688291
HTH,
Jim / crewzer
Wotf8 03-10-2019 05:50 PM
So true (except I Iove power), my ram weighed 8350 with fuel and myself. Left 1650 pounds of legal payload. But it was sprong very stiff, you could put a whole 60 bag skid of sand blasting sand I the back and it hardly squatted. Once I slide in 55 bags of concrete and it only dropped 4"
xrated 03-10-2019 07:55 PM
My 2011 F250 CrewCab, 4x4 Diesel, XLT, had a whopping 2148 lbs of payload. The Lariat, King Ranch, and Platinum will have even less because they have more equipment on them.
Wotf8 03-10-2019 08:49 PM
That is what my new king ranch has for payload on the door.
Wotf8 03-10-2019 08:52 PM
Finally got to drive the pickup today on I75 without the trailer on and it has a bit of that loose feeling on the road. Really thinking it is tire related.
Army RET 03-10-2019 09:01 PM
Are the tires running at the recommended pressures (as noted on the door jam sticker) or are you winging that?
Wotf8 03-10-2019 09:27 PM
At 60 and 65 now, what the door says.
Army RET 03-10-2019 09:34 PM
If the pressure is correct (as you say) then I'd suspect the roadway itself. Oftentimes heavy trucks create tracks (generally in the slow lane) that may lead others to feel loose. Try another stretch of highway.
HRTKD 03-10-2019 09:39 PM
Possibly bad suspension components? Something is loose? Maybe the alignment is way off?
My F-350 with an 11K bumper pull travel trailer doesn't wander. I do get a slight buffeting when someone passes me. That's not uncommon for a travel trailer. Rare for a 5th wheel.
Wotf8 03-11-2019 07:39 AM
If you can pull an 11000 pound (must be pretty long) bumper pull travel trailer and not be uncomfortable, that is pretty awesome.
HRTKD 03-11-2019 08:22 AM
It's actually rather short for a travel trailer. 25'6" from hitch to bumper. It's a toy hauler so the frame is beefy and it carries a lot of water.
flumpydog 03-11-2019 06:12 PM
Wotf8, while I cannot perhaps offer any good feedback here as to what might be causing this problem, I can say that adding a rear sway bar is not that expensive and in my case it made a noticeable difference in how my truck feels on the road. I went with the stock Ford unit and could not be happier, this might be worth doing in your case as it certainly will not hurt anything here.
Wotf8 03-11-2019 06:26 PM
Likely a good idea.
Mark250 03-12-2019 08:08 AM
Wotf8, a little off subject but how do you like the 6.7 compared to what I assume was a Cummins in your other truck?
