Carburetor Setups?
Those running 302, What Aftermarket 4-barrel carbs you all running? Trying to figure my options with the Ford Kickdown.
I'm about to get my 86 f150 back & it'll need a new Carb & maybe distributor as well. I was running a Quick-fuel 750CFM which was way too much carb for the motor, also failed mainly due to the floats sticking which caused flooding the motor & fouling the plugs to the point my oil was getting milky, not good. I ran the Edelbrock 1406 first but it seemed that the truck gasped for more air/fuel with that carb (Single fuel inlet). had the Jet adjustments wide open. I'm running larger Intake manifold, 202 heads, Ford X303 Cam. https://cimg2.ibsrv.net/gimg/www.for...c7c0fa794a.jpg https://cimg3.ibsrv.net/gimg/www.for...e22ab9ed48.jpg |
If the 750 was a vacuum secondary carb, it should work fine on that engine, especially since it's hopped up a little bit. Don't blame the carb for flooding the engine out, that is a common problem with a old truck and a rusty old fuel tank. It can also happen after a vehicle is first put on the road from construction debris in the fuel system like little chunks of rubber from fuel hoses and such.
I always run Holley 1850 600 cfm carbs. But my engines are stock. Why? Because they run right out of the box with no re-jetting, no hick-ups, etc. And I am familiar with them and how to work on them. |
(Post 18494000)
I bet if you took that carb apart and inspected the bottom of the bowls, you would find little rust flecks or some sort of debris down in there. I took a quick look at the carb, it is a Holley. The fuel levels are externally adjustable.. You can pull the float needle assembly out with the carb on the engine, and check it to see if it has something stuck in there. You also have to be careful with fuel pressure, a little too much will make the fuel levels high, you can adjust for this. Way too much will blow the needles open with no control over the fuel.
I like those types of carbs. Like I said I know all about them and like most people, I tend to like and stick with what I know. |
Havent installed it yet but I have a Summit 600 CFM 4V with vacuum secondaries to run on my '82. From the reading I did, these carbs are built for summit by Holley based off the old Ford 4100 4V carbs.
I got this one mainly because it was vacuum secondary as well as it had the ford kick down linkage already compared to edelbrock that required me to purchase an adapter that would lean the kick down out above the valve cover. https://cimg9.ibsrv.net/gimg/www.for...d52dd4a902.png |
Originally Posted by Rusty_S
(Post 18495572)
I got this one mainly because it was vacuum secondary as well as it had the ford kick down linkage already compared to edelbrock that required me to purchase an adapter that would lean the kick down out above the valve cover. https://cimg9.ibsrv.net/gimg/www.for...d52dd4a902.png After reading multiple reviews on this carb it sounds like a great value for the price! I think I'll be looking into this as my next Purchase. |
I know I caught this thread late but I have the 750 cfm Summit carb on my 71 Oldsmobile. It isn't worth the money you save. I wish I had got an Edelbrock or Holley carb instead. The Summit carb always needs tinkering (I've already put a kit in it). I've mentioned this on our site in other threads.
Originally Posted by Olds64
(Post 18496529)
Plus you cant get annular boosters in an edelbrock carb unless you are willing to pay close to $900. This summit carb comes with them and I haven't found a single holley that had annular boosters with a ford kick down. |
Rusty, a 4180 Motorcraft Holley has annular boosters in the primaries and has the Ford kick down.
I doubt you can a new one though. |
Originally Posted by Old Hickory
(Post 18496653)
The edelbrock has secondaries that work just as good as the holley. I prefer the holley because I know more about them, but I know the edelbrock has a spring loaded air door on top of the secondaries. If you nail the throttle, the secondaries do fly open underneath the air door on top. The air door regulates the air and fuel going to the secondaries, allowing only the amount the engine can use. This is all fully adjustable. Just like the Holley, this design allows a lot of forgiveness for carb sizing.
A lot of useful info. I'm still learning the tricks on tuning Carbs being I grew up in fuel injection age so its new old technology for me. The key is actually finding old school mechanics that knew how to tweek these just right.
I bought my Summit carb years ago. I imagine it is out of any warranty that might have come with it. Don't get me wrong, it isn't a hateful carburetor, but I know there are better ones out there. If you really want to save some money you might consider sourcing a used carb that just needs a rebuild. There's no better way to learn than to get hands-on experience.
FWIW, if you decide to buy the Summit carb here's a good book: Finding info on the Holley 4010 is hard to come by. The Summit carb was based on the Holley 4010 which was in turn based on the Motorcraft 4100. |
(Post 18497998)
FWIW, if you decide to buy the Summit carb here's a good book: https://www.amazon.com/Holley-Carbur...rburetor+books Finding info on the Holley 4010 is hard to come by. The Summit carb was based on the Holley 4010 which was in turn based on the Motorcraft 4100. |
BTW, that's an AWESOME truck! I love the rims. :-jammin
