Ford Truck Enthusiasts Forums
-   Modular V8 (4.6L, 5.4L) (https://www.ford-trucks.com/forums/forum48/)
-   -   4.6 Starter Shim? (https://www.ford-trucks.com/forums/1573097-4-6-starter-shim.html)
Claybreaker144 02-18-2019 08:24 PM
4.6 Starter Shim?
I have a 4.6 from a 03 Crown Vic in a 62 F100 with a T-45 tranny. I haven't put any miles on the truck but have had it running for about 6 month. It sat for a month with a dead battery and after a charge the starter would only click. I removed the starter and took it to the local repair shop and 3 hours later the starter is rebuilt. I install the starter and get the same results. I loosen 2 out of the 3 starter bolts and the engine starts right up. I'm thinking I need to shim this starter which is pretty much unheard of with a Ford. Doesn't appear to be any play in the starter location.
