Improving ride quality '89 F350...rsk?
So about 3 years ago I completed a Cummins swap and have been extremely happy so far. I've made some changes in my life and now my truck is currently my daily driver. Things that didnt bug me now irritate me on a daily basis. The main issue is how bumpy and terrible the ride is. I went from a 351w to a Cummins and never touched the suspension. I used to think the ride wasn't terrible but it's been so long I don't even remember anymore.
I'd like to improve the ride and I'm uncertain if a rsk will actually do that. For the price of an RSK I can almost buy Superduty axles and convert to coils (I know coils will ride better). I'm not sure if I need to buy new leafs because of the weight difference or were they all the same? The rear sits about 2.5" higher than the front. Any advice or suggestions? Thanks |
No love? Lol
An RSK does improve ride quality from what I've read both from the longer spring but also the improvement of the shackle location/angle. There are different ratings for the springs. I am planning an RSK from PMF in the next few months, seems to be around $800 give or take depending on some options.
The issue with the SD coil axle is that it has a different lug pattern if I remember reading, so you'd need to swap the rear as well. |
Originally Posted by nova801428
(Post 18487364)
Originally Posted by Edgethis
(Post 18489644)
The issue with the SD coil axle is that it has a different lug pattern if I remember reading, so you'd need to swap the rear as well. I've never ridden in a truck with an RSK so it's hard for me to know if it will be worth it. I'm in the process of swapping 05+ superduty axles in a project of mine. I wont know how it rides until late this year. |
I believe you can run the RSK, jsut need to box the front of the frame where it mounts.
Here's a kit: 87-91 F350 RSK Kit |
(Post 18489919)
Thanks for the reply. I don't believe there is a superduty leaf spring RSK for 87-91 trucks. I'm limited to using the stock length springs.
i got a stock 89 cc ongbed 4x4 with 351w and the ride is harsh i agree. i do have overload springs too from the factory, it bad on rough roads.
RSKs only really help if you’ve got a lift, therefore positive arch springs. If you’re stock, you have a negative arch, so as the axle moves up, it also moves back due to the front shackle. With a positive arch and stock shackles, the axle would have to move forward to go up, causing the pogo stick effect. I’m told the SD spring swap makes for a close to stock height with a softer ride gained from the length, and they can be had fairly cheap depending on where you live. |
The RSKs all use a SD spring and move the shackle to the rear. You will get a bit of lift from the swap just by the way its made.
(Post 18492806)
i think most the bad quality ride is from the rear springs.
(Post 18492919)
The RSK from sky specifically says it uses Ford 52" 80-97 leaf springs.
The better version (in my opinion) of RSks for our trucks come from PMF, they utilize the SD spring. Also their kit is bolt on and cheaper. I hadn't linked it before because it doesn't specifically say it'll fit 87-91. However, if you box the front frame rail I believe it'll fit. PMF SD spring RSK for 92-97 F350 |
I like the factory setup, it keeps the pinion angle more accurate and keeps the driveshaft from bottoming out
(Post 18492953)
You're right, that kit does say that. My bad for not double checking.
