1994 F-150 351W “SD” friendly cam
So I ordered the crane cams 444232 for my 1994 f-150 SD I pulled the stock cam out and was surprised to find it to be a roller cam. Now am I going backwards installing a flat tapped cam? I did put the 444232 cam in not everything completely back together and the stock push rods are approximately a half inch to short. Would the comp cams 35-349-8 be a better choice?Any help/info would be much appreciated. P.S. The truck is a 4x4 and has110000 miles with pacesetter long tube headers and 2.25 duel exhaust. Stock heads and stock intake manifold. |
Originally Posted by Joppy
(Post 18458733)
So I ordered the crane cams 444232 for my 1994 f-150 “SD” I pulled the stock cam out and was surprised to find it to be a roller cam.
(Post 18458733)
(Post 18458733)
I did put the 444232 cam in “not everything completely back together” and the stock push rods are approximately a half inch to short.
(Post 18458733)
The crane 444232 came with new flat lifters, I’m looking for a cam that would give me more torque. In your opinion which would be a better cam, the crane 364211 or the comp cams 35-349-8? I really don’t want to mess with the heads at all, just a slide in cam. |
More low rpm torque or more peak torque?
Peak torque |
I ran 3 cams through DesktopDyno and the Crane 364211 makes the most peak torque and HP.. but not by a large margin. The Comp 35-349-8 is quite a bit cheaper and only gives up 3-4hp/tq to it, but that cam also produces 30tq and 40hp more than the stock cam which the program rates at 221hp/347tq with headers.
Will my stock lifters, springs, and push rods work with either of them? |
(Post 18459104)
Awesome thank you, my stock rockers are 1.6 so I should be good there. |
LIFTER TICK AFTER INSTALLING COMP CAM 31-255-5 IN MY 1990 F150
Originally Posted by Conanski
(Post 18458992)
Crane 364211 says 112* Lobe Separation and that dont play well with SD?
Comp 35-349-8 says 114* Lobe Separation and that works with SD and no tuning? |
Originally Posted by torq'ta 5 8
(Post 18486451)
