Hose leaking replacement question
https://cimg4.ibsrv.net/gimg/www.for...e0223cc9b1.jpg
I just had my radiator replaced the other day, and now it seems a hose is leaking from what i think is the transmission cooler. My question is, can just the rubber hose part be replaced or is it attached to the solid line? https://cimg6.ibsrv.net/gimg/www.for...720dd4ef88.jpg |
Slide the clamp up and give it a go. Looks like it was just slid on the nipple and never licked it.
Pair of pliers should do it. Rotate the line by hand once seated. Should be good. If it still leaks there, trim off the end of the hose so it loses it's memory and then reseal. Top off if necessary. Denny |
Originally Posted by DieselDenny
(Post 18428365)
Been married thirty two years, I just move the clamp from time to time. It'll work.
Denny |
(Post 18428960)
Denny |
Denny, you always put in a little extra.
Thanks :) |
(Post 18428365)
Well i brought the truck do the dealer to get looked at. Ended up having the complete tube assembly from the transmission cooler back replaced . lets hope this is the last of issues for a while
https://cimg8.ibsrv.net/gimg/www.for...daf97393f6.jpg |
