Not your average Crank No Start $50 Reward if you solve the issue.
I will gladly send $50.00 Amazon Gift Card to any single person who can help me fix this! I am desperate, I have been working on my F-250 for a month with no more idea's. I am not a newbie to mechanics, I have built several cars both gas and diesel, I have a well equipped shop however this is my first Power Stroke. After reading this forum for days and days, watching all of DieselTecRon's videos I surrender.
The truck is a 2004 F-250 with 260,000 miles. I have owned it for a little over a year. The problem started when I was warming it up one day and it just shut off like the key was switched off. I tried to start it again and it would not run. The Issue: When Turning Ignition on, I will see the Glow Plug Light, Water In Fuel will flash, Injector Clatter and Vacuum Pump, Here is the strange thing, The fuel pump will NOT turn on until after the injector clatter is finished. After waiting for fuel to pump and stop I will turn to crank, starter spins fast, until ICP reaches 500 psi, then I hear relays click the ecm appears to restart during mid crank, causing the starter to cutout,hesitate or stutter almost like it was hydro-locked. It will do this over and over. However if I jumped the starter with the remote start wire, ignition off, it will crank great at 160ish rpm. With ICP unplugged the Fuel Pump will turn on with ignition on (no delay) and the truck will start. What we have done to date..Long Back Story<p> I had some codes (however I was stupid and cleared them) I had an older problem in June with a P2290: Injector Control Pressure Too Low error code, that was not addressed. I tried just about everything, I had it towed to another mechanic who was a supposed power stroke guy, he wanted to replace all the injectors, starter, glow plugs, ficm, and ecm for a tune of $3,800. I told him thanks but hell no... I had it towed back to my shop and have been working on it ever sense. In order this is what I tried.
I needed to haul some materials to a building project, I stupidly drove it on a 4 hour trip with ICP unplugged, it ran pretty good however power was less. On the way back getting off the freeway it just died about 80 miles from home. I called the tow truck and waited for him to arrive, 50 minutes later I was checking my torque gauges and low and behold it started again! I thought ok, crank no start hot? I had it towed anyway, it was late. I got it home, and it would never start again. With the new ICP plugged in or not. However no stuttering starter
Sorry for such a long post, I am just trying to be thorough and not waist time. My wife and Son's are growing silently disappointing in my abilities as am I. I rarely ask for help, but dang it. I don't know where to go from here. |
Is your ICP a Ford one or aftermarket?
Quote - "it now spins fast until ICP reaches near 500 then will make a grinding noise.". Can you pinpoint where the grinding noise is coming from? Just to confirm - After all the work in the HPO system, it will now start and run normally with the ICP unplugged? |
The icp I purchased was aftermarket, I just got off the phone with the dealer $168 for motor-craft.
Aftermarket ICPs have caused numerous issues. Not to say they all will, but it is a disappointingly high percentage.
Find someone w/ a working truck and borrow their ICP sensor. I could send you one for a $50 deposit if that helps any (I want it back), but it would be better to borrow one from someone you know there. |
Another option is to go to the sub-forum for your state and see if anyone lives close by that could help.
i have an ICP sensor
Send me a PM if youre interested. It’s used but a good ICP. You can have it. So I've tried to upload an image about 100 times. Won't work. ANyway, it's a good ICP. If you want it PM me with address. You can have it. It's collecting dust. Dan |
Did you try a new ICP pigtail?
Originally Posted by jmaskew
(Post 18422592)
BUT, that doesn't mean it's not shorting out somewhere in the harness. First though you gotta get rid of the aftermarket ICP sensor. I've never heard any good about them. It's Motorcraft or nothing. |
Its not the ICP
Well its not the ICP, I got a known working ICP and and same deal. I got creative and installed a dc/dc 5v converter and wired it directly from the battery to the old ICP pigtail. I tied in an inline voltmeter to signal Ç pin and instantly had .2 volts! I got brave and clipped the test pigtail to the icp installed on engine. Leaving the pcm pigtail unplugged. Started it and nice 1.3 volts. Next I took a lead from my test piggy and plugged it in to the C pin on to pcm pigtail. Worked perfectly! What kills me is vref looks fine at 4.9 volts but as soon as I plug it in the pcm act's crazy. So now what?
When you installed the new pigtail, you didn't get the wires mis-matched did you?
I followed the manual B= +5 C= Sensor Out A = Return/ground
https://cimg7.ibsrv.net/gimg/www.for...de1ef85cbc.jpg |
the 5V reference (bn-wh) goes in your position A (looking from the back)
the ground (or they call it the monitor) (gy-rd) goes in your position B the signal return (db-lg) goes in your position C like you have it. https://www.ford-trucks.com/g/picture/806129 Turn the harness so that the connector snap clip is at the 12:00 position, you will be looking at the back of the connector (at the wires). The gray w/ red wire (gy-rd) should go to the top left (it looks like this one is still connected in the pic I linked to in my FTE album). This is the ground. Go clockwise from there to the top right - the next wire is the brown w/ white (bn-wh), this is the 5V Ref wire (vref). Then dark blue w/ light green (db-lg) is at the 6:00 position - this goes to the PCM. You have the 5V reference and ground wires reversed. The PCM doesn't try to ground the sensor until the key is turned on, that is when the PCM goes wonky.. |
So is it possible that when you put it back together that you pinched a wire in the valve cover. I ask because I've seen it done before. Not this exact thing to be clear, but a pinched wire in the valve cover causing problems
Originally Posted by Nummy76
(Post 18423403)
Originally Posted by bismic
(Post 18422858)
the 5V reference (bn-wh) goes in position A.
the ground (gy-rd) goes in position B the signal return (db-lg) goes in position C like you have it https://www.ford-trucks.com/g/picture/806129 Turn the harness so that the connector snap clip is at the 12:00 position, you will be looking at the back of the connector (at the wires). The gray w/ red wire (gy-rd) should go to the top left (it looks like this one is still connected in the pic I linked to in my FTE album). This is the ground. Go clockwise from there to the top right - the next wire is the brown w/ white (bn-wh), this is the 5V Ref wire (vref). Then dark blue w/ light green (db-lg) is at the 6:00 position - this goes to the PCM. You have the 5V reference and ground wires reversed. The PCM doesn't try to ground the sensor until the key is turned on, that is when the PCM goes wonky.. I don't know, but I'm thinking that's the amazon card right there... |
